aristotle_kumpis Posted May 14, 2014 Report Share Posted May 14, 2014 Have any of you painted a lav mic? I want to paint mine a different color, but I'm not sure which type of paint to use. Quote Link to comment Share on other sites More sharing options...
Jay Rose Posted May 14, 2014 Report Share Posted May 14, 2014 Can you wrap it in white paper tape, and use markers? Lots more undoable than paint, and you can trim the tape with an xacto to make sure it doesn't get near the grill / input hole. Quote Link to comment Share on other sites More sharing options...
nickreich Posted May 15, 2014 Report Share Posted May 15, 2014 yes, we do it all the time in the Theatre. The best paint to use for MOST lavs is the little cans of spray-on shoe paint. It's designed for changing the colour of leather shoes, so is still flexible when dry. First put a little square of Gaffa tape or waterproof first aid tape over the grille, hang the mic straight down then do multiple sprays from a greater distance then you would normally think - so it doesn't get too thick. We often use a couple of colours as speckled overspray to match performers hair colour. A few brands of mic, such as the latest Sennheiser MKE-1 cable formulation, don't work as well with the shoe paint, and you have to use the little cans of model aircraft paint instead, but even that comes off in a week or so. Test your paint on a dead lav first if possible. We've tried the paper tape idea too, but it makes the lav to inflexible for head-mounts. May work OK for other types of mount. Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted May 15, 2014 Report Share Posted May 15, 2014 You could try plasti dip - http://www.plastidip.co.uk/ That way, if you don't like the colour, you can simply peel it off. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 15, 2014 Report Share Posted May 15, 2014 AK: " Have any of you painted a lav mic? " yes. EV used to make a model specifically for painting! Quote Link to comment Share on other sites More sharing options...
aristotle_kumpis Posted May 20, 2014 Author Report Share Posted May 20, 2014 Thanks guys. I'll look into those options. Quote Link to comment Share on other sites More sharing options...
