FILMMIX Posted June 11, 2014 Report Share Posted June 11, 2014 I had a job where I needed more than 6 inputs (Mic Level) , so I figured I could use my 442 and link it to my 664 via the xlt a35 cable from Sound Devices. The problem is when using the cable from the mix out on the 442 to the mix in/out of the 664, the level is too low (0db tone from 442 reads Under -10 on 664) When I feed the 664 into the 442, all levels are fine (Tone reads 0db on both machines and the level down the mix bus is fine. Tested this setup with 2 other 442 mixers & 2 other xlt a35 cables. Has anyone else had this problem? I would love to be able to record the l&r mix on the 664 with the 442 feed. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 11, 2014 Report Share Posted June 11, 2014 Filmmix: " Has anyone else had this problem? " probably others have dealt with this issue, but I'm not even sure it is a problem as much as it is the way it is. you could and should contact SD for better information... in addition to their support forum, they have email and telephone Quote Link to comment Share on other sites More sharing options...
