Ze Frias Posted October 25, 2014 Report Share Posted October 25, 2014 maxx already has a stereo TX that carries TC . it might be able to carry the zaxnet command with the TC over RF to a QRX235 on camera which will send commands over zaxnet 2.4ghz While I understand that a built in TX in the Maxx is feasible, and that it is the best way to go for lightest and most compact solution, I am also looking to keep Zaxnet in my bag, and I want modularity. Instead of getting an IFB200, I would rather pay the extra bit and get a CL that I can use in both my Nomad rig, and my potential future Maxx rig. I wouldn't always use the UHF transmitter, but I use the Zaxnet transmitter ALL the time. I also would prefer to keep using wideband QRXs for both bags, which I already own, instead of getting a 235/100QIFB to use in a bag (those are for cameras ;P) Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 25, 2014 Report Share Posted October 25, 2014 Jose has a very good point - a camera link vs the built in transmitter is a very good option. The camera link integration is nice but the advantages of the CL may out way the intergration for some. The CL will give you a stereo UHF transmitter with tc, a zaxnet transceiver that can control your wirless and send audio and tc to ERX receivers and you also get an backup two track recorder. All in one small box. The CL files also can be an easy converted to an mp3 with tc for transcription or converted to wav as a mix track. The ifb200 is the exact same size of the camera link so if you are looking at a ifb200 the functionality of the CL may be an advantage for some. While one solution may work for one person, someone else might want something different. The good thing is you have options that work for you. Quote Link to comment Share on other sites More sharing options...
cory Posted October 25, 2014 Report Share Posted October 25, 2014 Just as Rado has mentioned, would be awesome if the internal CL could send zaxnet commands over TC. I'm all about saving space in the bag! Quote Link to comment Share on other sites More sharing options...
howy Posted October 25, 2014 Report Share Posted October 25, 2014 Note that I just made new software for the CL camera link and the IFB200 that supports the Zaxnet commands that come from Maxx. It is LNK-165. Also I believe you need at least version QOPT-158 to be able to use MAXX's zaxnet with the QIFB in a QRX-235 or QRX-100. I will try to make sure this is all on the zaxcom forum today. -howy Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 25, 2014 Author Report Share Posted October 25, 2014 While I understand that a built in TX in the Maxx is feasible, and that it is the best way to go for lightest and most compact solution, I am also looking to keep Zaxnet in my bag, and I want modularity. Instead of getting an IFB200, I would rather pay the extra bit and get a CL that I can use in both my Nomad rig, and my potential future Maxx rig. I wouldn't always use the UHF transmitter, but I use the Zaxnet transmitter ALL the time. I also would prefer to keep using wideband QRXs for both bags, which I already own, instead of getting a 235/100QIFB to use in a bag (those are for cameras ;P) Makes sense Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 25, 2014 Author Report Share Posted October 25, 2014 And the maxx TX is a very small band Jose has a very good point - a camera link vs the built in transmitter is a very good option. The camera link integration is nice but the advantages of the CL may out way the intergration for some. The CL will give you a stereo UHF transmitter with tc, a zaxnet transceiver that can control your wirless and send audio and tc to ERX receivers and you also get an backup two track recorder. All in one small box. The CL files also can be an easy converted to an mp3 with tc for transcription or converted to wav as a mix track. The ifb200 is the exact same size of the camera link so if you are looking at a ifb200 the functionality of the CL may be an advantage for some. While one solution may work for one person, someone else might want something different. The good thing is you have options that work for you. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 25, 2014 Author Report Share Posted October 25, 2014 Howy, Thank you again and again for your magnificent work!!! Any chance to get LOW, WakeUp On powermode commands as well? Note that I just made new software for the CL camera link and the IFB200 that supports the Zaxnet commands that come from Maxx. It is LNK-165. Also I believe you need at least version QOPT-158 to be able to use MAXX's zaxnet with the QIFB in a QRX-235 or QRX-100. I will try to make sure this is all on the zaxcom forum today. -howy Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 25, 2014 Report Share Posted October 25, 2014 And the maxx TX is a very small band The Maxx transmitter as well as the Camera link is single block and not wide band like the LA and LT transmitters. So if you are going to be getting either a CL or an internal transmitter in Maxx you will need to have it block specific. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 25, 2014 Author Report Share Posted October 25, 2014 Jack, My maxx is not a single block! It is 2/3rd of a block 545MHZ to 565MHZ Quote Link to comment Share on other sites More sharing options...
Jan Moss Posted October 4, 2020 Report Share Posted October 4, 2020 Hey, I remember reading this thread some two years ago and now I'm planning to give my Maxx another life by connecting it to IFB200/QRX235. So I wonder - is there anything that IFB100/200 has that QRX100QIBF/235 is missing? Or in another words: is IFB same like QRX with an extra 4-channel receiver? best wishes to you all. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 4, 2020 Author Report Share Posted October 4, 2020 The only thing missing is auto tune when you scan and gain level. I dont remember if individual sleep was in the Maxx because mine was stolen and don't have it anymore. Other than that it is great to keep everything consistent and control from Maxx. Quote Link to comment Share on other sites More sharing options...
