Lancashire soundie Posted August 28, 2014 Report Share Posted August 28, 2014 I wonder, does anyone know of a nice "gadget" to allow me to plug into modern cameras like the F5/F55/C300/FS700 etc, without the tails dangling down wherever they fall? Take this as an example: http://www.pinknoise-systems.co.uk/Ambient_QAT_Top_Tip_XLR_Mount--product--1917.html I'd love something similar. Imagine if the microphone output were replaced with a Tajimi socket, screwed tight to the camera handle, and the 2 outputs+return were on extremely lightweight cable? Does anyone know of such a thing? Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 28, 2014 Report Share Posted August 28, 2014 How about a 2 channel wireless receiver? That would eliminate the camera tail. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted August 28, 2014 Report Share Posted August 28, 2014 Lan: " Does anyone know of such a thing? " there are so many possible variations, but numerous clever folks have come up with their own custom solutions... Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted August 28, 2014 Report Share Posted August 28, 2014 The show I'm working on now has an F5. We made our own tails, using right angle XLRs that are pointing upwards toward the top of the camera. That way the cable can hang from the handle on top and be secured by a strap or something. Works good. But we're mostly rolling wirelessly anyway Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted August 28, 2014 Report Share Posted August 28, 2014 the layout will vary from camera to camera and is not practical Quote Link to comment Share on other sites More sharing options...
johngooch Posted August 29, 2014 Report Share Posted August 29, 2014 +1 JIm. I can connect and disconnect the engh 7pins very fast. simple and cheap. Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted August 29, 2014 Author Report Share Posted August 29, 2014 It isn't just about aesthetics, but if you look at a typical F5 setup there aren't many options to be tidy, what with all the equipment bolted onto them. A lot of my work lately has been onto one of these, with this rig: I thought it might be nice to have something functional that could bolt onto one of the holes up near the handle. I think it'd be much better to have the socket end of the tails securely fastened to the camera - that way, you could have thinner lighter cables that don't need to be as strong as normal tails. Relationships with cameramen are very important, if I can provide kit that makes their job easier, or that doesn't scratch the camera through random movement, I will. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted August 29, 2014 Report Share Posted August 29, 2014 lancashire: " I thought it might be nice to have something functional that could bolt onto... " feel free to design and invent one... then, of course you may market it; keep us posted. Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted August 30, 2014 Author Report Share Posted August 30, 2014 Do you ever post anything constructive, or do you spend your days trawling forums trying to be a massive arsehole? I asked if anyone knew of such a device's availability, and everyone else helped. I didn't ask for career advice. Is there a block option on this forum, so I don't have to read this idiot's postings? Quote Link to comment Share on other sites More sharing options...
macrecorder Posted August 30, 2014 Report Share Posted August 30, 2014 Yes, Lancashire, just click on your profile and go to manage ignore prefs, and insert name of idiot in there. Bliss. No more juvenile condescending smartassery. Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted August 30, 2014 Author Report Share Posted August 30, 2014 Thanks macrecorder, I've done that. Quote Link to comment Share on other sites More sharing options...
BVS Posted August 31, 2014 Report Share Posted August 31, 2014 http://www.comac.co.nz/modules/SP_webshop/products.php?cat=109 I use an older solid rubber version of this rubber rope tensioner... Plug your XLRs in to the camera then thread the pig tail side of your breakaway Neutrik multi pin connector through one hole of the tensioner and bring the cable around the handgrip or other protusion on the camera and partially into the other hole of the tensioner so its gripped in the other rubber hole...and adjust the cable size to suit......then connect the other part of the breakaway Neutrik and the cable going to the mixer... this can easily be disconnected by holding the rubber with the connector....your main cable comes apart easily and is endlessly repeatable ... Quote Link to comment Share on other sites More sharing options...
TomBoisseau Posted August 31, 2014 Report Share Posted August 31, 2014 I suspect you are already familiar with the BetaBox by Ravencourt. I love them when they work, however they will not fit every camera. The other negative is that they fit so nicely on the camera that it is easy to forget it's on there and you end up leaving for the day with it still attached. http://filmebase.pt/Ravencourt/index.html tom Quote Link to comment Share on other sites More sharing options...
Lancashire soundie Posted September 1, 2014 Author Report Share Posted September 1, 2014 Yes I've seen the Betabox (not for years, mind), but they're unsuitable for modern cameras. What I'm after is a betabox where the outputs/return are on lightweight cable, and the "box" with integral multipin connector screws or bolts onto a standard thread somewhere on the camera. I suppose nobody makes them which, considering the proliferation of new cameras, is somewhat disappointing. Quote Link to comment Share on other sites More sharing options...
