900MHz GSM Yagi directional antenna
resonate
Hello All,
I'm thinking about adding this http://www.ebay.co.uk/itm/300441519823 antenna to my micron SDA 214-1 splitter/amplifier setup. All of my wireless (Micron, Audio LTD) are in the CH69-70 frequency range.
1) is it okay that the antenna works up to 960 Mhz range? Will the micron SDA 214-1 amplify only the range that it works in? (833-865 Mhz) I wonder because all of the cellular towers start at 870 Mhz in  Poland and use 900-960 band also. Would it be better to have a yagi that works within Ch69,70 only?
2) i am planning to use extender male SMA->N female panel connector cables to attach them to the bag (http://www.ebay.co.uk/itm/300380267074?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649, http://www.ebay.co.uk/itm/N-male-N-male-plug-pigtail-semi-rigid-cable-RG402-/300486126120?pt=UK_Computing_Boosters_Extenders_Antennas&hash=item45f65e6a28), so i can switch between coax dipoles and a higher gain antenna like the yagi above, as long as the connectors are ok, the loss at the connectors is neglible,right?
Thanks for your attention,
Bartosz
