Hugh Holesome Posted July 29, 2008 Report Share Posted July 29, 2008 If I close the program and or eject the hard drives I am unable to successfully relaunch BR without creating new directories? The program worked flawlessly during the 30 day trial but since purchase this has happened repeatedly...at least 4 times this past week. Restarting Macbook pro does not factor. The only workaround is starting BR with drives undocked then creating new folders after the drives are reinstalled. Not optimal to do for just a lunch break Genie shutdown, etc I'm mirroring using 1 FW500GB and 1 USB250GB with BR 7.22 / 2G RAM Again, for a 18 day shoot during trial period seamless on/off cycling Any other experiences or fixes? Please advise Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted July 29, 2008 Report Share Posted July 29, 2008 Have you emailed Take? support@vosgames.nl He's very helpful. Philip Perkins Quote Link to comment Share on other sites More sharing options...
Hugh Holesome Posted July 29, 2008 Author Report Share Posted July 29, 2008 Have you emailed Take? support@vosgames.nl He's very helpful. Philip Perkins Yes, I cc:d him but thought I'd check with the group also. Quote Link to comment Share on other sites More sharing options...
JBucher Posted July 29, 2008 Report Share Posted July 29, 2008 I had a similar issue once (although not exactly) and the problem ended up being illegal characters in one of the fields in the report. Is the report showing up correctly? Are you using an external keyboard? Or, have you tried the obvious of uninstalling the program and then reinstalling it? Quote Link to comment Share on other sites More sharing options...
Noiz2 Posted July 29, 2008 Report Share Posted July 29, 2008 I just had something similar happen. I inadvertently trashed a folder that I had one set of files pointed at. Going into record caused a freeze and a sudden quit. After that even recreating the folder didn't stop the sudden quit at launch. What I had to do was delete the files that had been created in the in the first record session. Explanation... I had discrete tracks going to one folder and three crash down mixes going to three other folders. BR had already created files in the existing directories before it locked up trying to write to the nonexistent fourth directory. I don't think I would have had a problem if I had not gone into record and created the corrupt files. I'm pretty sure that BR has handled bad paths better in the past but? Anyway I emailed Take also so I'm sure a fix will be forth coming. Quote Link to comment Share on other sites More sharing options...
Noiz2 Posted July 29, 2008 Report Share Posted July 29, 2008 I just did a quick test and with my record drive not attached opening BR and going into record throws an appropriate error. I would check for a corrupt file in one of BR paths. Quote Link to comment Share on other sites More sharing options...
Hugh Holesome Posted August 11, 2008 Author Report Share Posted August 11, 2008 Thanks guys, Yes basically corrupt path. I go to 2 drives, 1 for me and 1 for production. Their USB cable was flaky and was replaced and no error since! Quote Link to comment Share on other sites More sharing options...
