Not to mention 788T has limiters on AES inputs and full 8 channels. "Nomad has 8 AES Only if you sacrifice Zaxnet"
If it was not for the zaxnet, the superior routing and better interface I would be using a 788T.
For the limiters... Nothing else.
If you don't mind my asking, purely out of curiosity, what is it that makes the Nomad's routing capabilities better than the 788T's? Also the better interface?
This is not meant as another heated "this is better than that" discussion, I'm only curious
as far as interface it is subjective , routing clearly better... Just the fact that I have 2 different com and slate . The routing matrix l the outputs and inputs....
Ok, com and slate isn't routing, that's another function. The 788 with CL-9 does have that, too, but that's not the point. On the 788 you can route any input (and any number inputs) to any track and any output. What would the Nomad be doing better in this regard?
I bet I'd agree about the interface. I don't know it on the Nomad, but on the 788, I am not very thrilled
