realsnd Posted September 23, 2014 Report Posted September 23, 2014 Dear all, I’ve recorded some tracks in double MS and wandered if anyone has ever attempted to use the rear and fig-of-8 channels to increase (in post) the lateral and rear rejection of the front mic. The end result would be a super-directional mono (virtual) mic. This would be useful to adjust in post tracks recorded in uncontrolled environments, e.g. documentary setting, direct cinema style, no time to change mics or lav people. Is the idea making sense at all? If it is, any suggestion to make it work? My set up was a CMIT (front), CCM41 (rear), and CCM8 (Fig-of- inside a Cinela PIA-3, recorded on a Nomad with the three inputs with identical fader and trim settings, no compressor/limiter involved. The typical track: a quiet river surrounded by open fields, a man bathing 3m in front, an engine 100m in the back, kids babbling on the sides from various distances. The three channels are quite contrasted but the front mic still got too much engine and kids. The goal is to get a mono track with the kids, and more importantly the engine, attenuated. I played around with Schoeps' DMS plugin.http://www.schoeps.de/en/products/dms_plugin/overview The displayed polar patterns suggests that I could achieve complete rejection of rear and attenuation of side with some settings and using only the center channel (from DMS decoded as 5.1). But the actual result is unimpressive and there is some distorsion if I push it too far. So, what’s your take on this? Quote
studiomprd Posted September 23, 2014 Report Posted September 23, 2014 welcome snd: " So, what’s your take on this? " trial and error, have fun. Quote
VM Posted September 23, 2014 Report Posted September 23, 2014 Of course you can. You should have better results with "double MStools BF", the other Schoeps plug in that is more complete. Quote
realsnd Posted September 24, 2014 Author Report Posted September 24, 2014 Thanks for the replys. The plugin I was refeering to was actually the Double MS tool BF from Schoeps (wrong link in my previous mail, correct link is http://www.schoeps.de/en/products/dms_plugin_bf). Cancellation of the CMIT's rear lobe was not very effective, some phase-related distortions appeared with the most extreme settings of the "Focus' parameter, which was the most effective. So, I'd appreciate alternative ideas, other plugins, insights on the theoretical problem, etc. Quote
pkautzsch Posted September 25, 2014 Report Posted September 25, 2014 The Sanken CS-3e works with multiple capsules, the Super-CMIT uses an "intelligent" DSP. The new Sanken CSR-2 is supposed to have nearly as good cancellation as the Super-CMIT, but in the analog domain. So although the principle of multiple capsules and phase cancellation works, the details apparently need lots of engineering. I think the basic problem is this. A shotgun's or hyper's rear lobe usually is polarity inverted. The more "shotgun-y", the more angle-dependent and frequency-dependent these rear lobes are. So if you just put a backward-facing cardioid on top, you might improve the pattern in some frequency ranges, but make it worse in other ranges. You'd have to have a "cancelling" pattern that's very close to the backward lobes to be effective. Quote
Wandering Ear Posted September 25, 2014 Report Posted September 25, 2014 The capsules in a sanken shotgun are so close together they can remain phase coherent up to fairly high frequencies. The capsules on your dms rig are too far separated to be truly phase coherent. This will always be a limiting factor in this type of rig, as your tests have proven. Quote
realsnd Posted September 25, 2014 Author Report Posted September 25, 2014 The capsules in a sanken shotgun are so close together they can remain phase coherent up to fairly high frequencies. The capsules on your dms rig are too far separated to be truly phase coherent. This will always be a limiting factor in this type of rig, as your tests have proven. As matter of fact, my tests suggest you're right, but there is something that bother me. If capsules' coincidence is good enough for 5.1 decoding---which involves some cancellation---why isn't it good enough for rear cancellation? In this set up, the CMIT and the CCM41 capsules are on the same plane, approximately orthogonal to the mic-rear sound axis. The wave length at 1000Hz is about 34cm, the distance between the capsules on this axis is about 100 times smaller. So it seems negligible, considering we are talking about an diesel engine sound quite muffled, 100m away. Quote
studiomprd Posted September 25, 2014 Report Posted September 25, 2014 rs: " If capsules' coincidence is good enough for 5.1 decoding---which involves some cancellation---why isn't it good enough for rear cancellation? " the laws of physics, perhaps..? Quote
pkautzsch Posted September 26, 2014 Report Posted September 26, 2014 A Schoeps 41 capsule is a "hyper" too, so it has that back lobe. Pointing it backwards on top of a shotgun will result in the hyper's back lobe pointing forward. Quote
realsnd Posted September 26, 2014 Author Report Posted September 26, 2014 A Schoeps 41 capsule is a "hyper" too, so it has that back lobe. Pointing it backwards on top of a shotgun will result in the hyper's back lobe pointing forward. That must be a limiting factor, indeed. According to Shoepd polar diagram the lobe is -10dB compare to front below 2khz, I don't know if that's the reason for cancellation failure. (see http://www.schoeps.de/en/products/ccm41/graphics) Regading coincidence, I have assumed the mic placement displayed on the Cinela site was correct (see attached image), but I am not 100% sure of where exactly the capsule is inside the CMIT. Is there someone expert enough to confirm this is the optimal placement? (I can satisfactorily decode MS on both rear and front, so it is at least OK, but perhaps not optimal). Since I am on the topic of mic placement, Does any one see any specific reason why is the CCM8 on top and the CCM41 below? It seems odd because the CMIT suspension gets in the way of the CCM41 in the set up and would be better place on top, no? Quote
realsnd Posted November 17, 2014 Author Report Posted November 17, 2014 After an inquiry to Schoeps about capsules positions within the mics: ---- The distances from front grill to diaphragm are: CMIT: 92,5mm CCM8: 14,5mm CCM41: 4mm ---- This helped me and will possibly help others to precisely position the mics (the perspective in the photo above gives slightly distorted picture of the optimal position in my view). Quote
