daniel Posted October 14, 2014 Report Share Posted October 14, 2014 If the cos 11d is terminated for Lecto, Sennheiser 3.5mm or Shure, it will work. i see there is a sony hirose option - but this wont work with cos-11 wired for this sony connector? Quote Link to comment Share on other sites More sharing options...
lamacchiacosta Posted October 14, 2014 Report Share Posted October 14, 2014 Hi, what about input with mini lemo 3 pins connectors, for hi end Sennheiser and Wisycom and Zaxcom. Also the jack 3.5" Sennheiser in not lockable, which is very dangerous with an high risk of loosing connection. Great machine though! :-) Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted October 14, 2014 Report Share Posted October 14, 2014 Very good point about the Sennheiser connections not being lockable as they are on Sennheiser wireless. Something that should be corrected ASAP. Quote Link to comment Share on other sites More sharing options...
pindrop Posted October 14, 2014 Report Share Posted October 14, 2014 Hi, what about input with mini lemo 3 pins connectors, for hi end Sennheiser and Wisycom and Zaxcom........ This would be very useful, I have mics terminated large 6 pin Lemo (Audio Ltd) small 6 pin Lemo (Micron) and 3pin Lemo (Zaxcom) and micro dot (DPA) none of which would work directly without an adapter lead, are there any plans for more user changeable top plate connector options? Quote Link to comment Share on other sites More sharing options...
BudRaymond Posted October 14, 2014 Report Share Posted October 14, 2014 20ppm is better than the average DSLR, and better than a lot of other cameras that aren't Lockit'ed. We did our homework on the Lectro, the top plate has a couple of switches on it (inside). When sitting passively between Lav and Tx, there is no difference, but for providing power stand-alone, one position works with original non-servo mics, and the other position works with universal and servo bias wired Lavs. We've been testing with both. I expect that the advice you'd get from anywhere would be to re-wire old mics to universal wiring anyway... One of the Lectro 152 mics I got turned out to be a 150 with just the label changed (they are the same capsule) - took us a while to figure out it was original wiring. Nice job guys. Great product and price point. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 14, 2014 Report Share Posted October 14, 2014 ET: " Something that should be corrected " corrected ? well, maybe the price point should be corrected, too... I'd like it to be $129. Quote Link to comment Share on other sites More sharing options...
Tom Duffy Posted October 14, 2014 Author Report Share Posted October 14, 2014 i see there is a sony hirose option - but this wont work with cos-11 wired for this sony connector? Should work fine, I'm not personally familiar with the Sony pin assignment. Hi, what about input with mini lemo 3 pins connectors, for hi end Sennheiser and Wisycom and Zaxcom. Also the jack 3.5" Sennheiser in not lockable, which is very dangerous with an high risk of loosing connection. Great machine though! :-) We'll consider the Lemo, does everyone wire those the same? The Senn 3.5mm is lockable, already tested. The through cable it comes with is also lockable connectors on both ends. Tom (TASCAM) Quote Link to comment Share on other sites More sharing options...
Tom Duffy Posted October 14, 2014 Author Report Share Posted October 14, 2014 the 20 ppm for the clock is not good I'm thinking of trying the XLR adaptor for the Nagra SD I just checked now and the part being used is 15ppm Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted October 14, 2014 Report Share Posted October 14, 2014 If this thing had timecode, it'd be a killer. You should talk to Tentacle Sync for the MKII. And I too second the opinion that there should be a 3 pin lemo adapter. In Sweden, 95% of the time the wireless system is either Wisycom Lemo or microdot. Always DPA lavs. I can't see Microdot happening on this little machine, but it would make sense somehow sizewise. Great product nonetheless! You'll sell a bunch I reckon. Quote Link to comment Share on other sites More sharing options...
Vincent R. Posted October 15, 2014 Report Share Posted October 15, 2014 If this thing had timecode, it'd be a killer. You should talk to Tentacle Sync for the MKII. Yeah I opened the tentacle sync to see what's inside. The PCB is about 2x2 CM, that could fit anywhere. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted October 15, 2014 Report Share Posted October 15, 2014 It's a win win. Quote Link to comment Share on other sites More sharing options...
karlw Posted October 17, 2014 Report Share Posted October 17, 2014 Saw this unit at AES and it looks good - very small. I was impressed after talking with Tom Duffy about it - they have done their homework on the inputs. Quote Link to comment Share on other sites More sharing options...
Andysound Posted October 29, 2014 Report Share Posted October 29, 2014 Hey Tom, I've been bugging Sound Devices for something like this for years. Great tool for Wireless Booms on Film/TV sets where our chances for drop outs are getting more frequent. So my couple questions.... Whats the record time per GB Can you turn off the "Backup Track" to get more record time What happens when you get to the end of the card, i.e. will it "Loop Record" like the Zaxcom or just stop recording Thanks again, I hope to convince the Mixer I work with to get a couple for the Boom Ops Andy Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 29, 2014 Report Share Posted October 29, 2014 Andy: " Whats the record time per GB " that one is easy: the recording time per GB is the same for all devices when recording industry standard .wav (aka bwf) files. Quote Link to comment Share on other sites More sharing options...
VASI Posted October 29, 2014 Report Share Posted October 29, 2014 Hi Andy, 1 track, 48kHz/24bit, WAV, 32GB card = 66 hours and 17 minutes You can check this here. Quote Link to comment Share on other sites More sharing options...
Andysound Posted October 29, 2014 Report Share Posted October 29, 2014 Hi Andy, 1 track, 48kHz/24bit, WAV, 32GB card = 66 hours and 17 minutes You can check this here. Thanks Vasileios Quote Link to comment Share on other sites More sharing options...
d3sound Posted October 30, 2014 Report Share Posted October 30, 2014 How much delay in the signal? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted October 30, 2014 Report Share Posted October 30, 2014 How much delay in the signal? Zero, its an analogue split. The signal will continue to pass through to the output even if this unit's battery dies. Quote Link to comment Share on other sites More sharing options...
Tom Duffy Posted October 30, 2014 Author Report Share Posted October 30, 2014 The DR-10 is indeed an analog split of the input signal, so no delay and no interruption on battery end. Official battery life: Alkaline 10 hours Eneloop Pro 8 hours Energizer Ultimate Lithium 15.5 hours Mono files are recorded. In dual mode you get 2 mono files, and half the capacity. At media full, recording stops. Tom (TASCAM) Quote Link to comment Share on other sites More sharing options...
d3sound Posted October 30, 2014 Report Share Posted October 30, 2014 Nice thanks Tom.... Quote Link to comment Share on other sites More sharing options...
OmahaAudio Posted October 31, 2014 Report Share Posted October 31, 2014 Andy: " Whats the record time per GB " that one is easy: the recording time per GB is the same for all devices when recording industry standard .wav (aka bwf) files. So, once again, you provide no useful information. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 31, 2014 Report Share Posted October 31, 2014 Jim: " So, once again,... " I let folks do their own homework. While, OTOH, your post was not just useful, but also inspiring... Quote Link to comment Share on other sites More sharing options...
dfisk Posted October 31, 2014 Report Share Posted October 31, 2014 If I remember correctly (and someone correct me if I'm wrong)...I think recording time per gb is about an hour of 2 tracks bwav at 48Khz 24bit. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted October 31, 2014 Report Share Posted October 31, 2014 "I think recording time per gb is about an hour of 2 tracks bwav at 48Khz 24bit." .. Or approx. 7.6MB per track minute (455MB per track hour) Sorry Senator, we probably should have let the lazy folks figure it out for themselves. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 31, 2014 Report Share Posted October 31, 2014 RR: " Sorry Senator, " fine by me... and once again thanks to Omaha for his valuable important informative helpful note-worthy contribution... Quote Link to comment Share on other sites More sharing options...
