Tom Duffy
TASCAM DR-10C, DR-10X
If the cos 11d is terminated for Lecto, Sennheiser 3.5mm or Shure, it will work.
i see there is a sony hirose option - but this wont work with cos-11 wired for this sony connector?
Hi,
what about input with mini lemo 3 pins connectors, for hi end Sennheiser and Wisycom and Zaxcom. Also the jack 3.5" Sennheiser in not lockable, which is very dangerous with an high risk of loosing connection.
Great machine though!
Hi,
what about input with mini lemo 3 pins connectors, for hi end Sennheiser and Wisycom and Zaxcom........
This would be very useful, I have mics terminated large 6 pin Lemo (Audio Ltd) small 6 pin Lemo (Micron) and 3pin Lemo (Zaxcom) and micro dot (DPA) none of which would work directly without an adapter lead, are there any plans for more user changeable top plate connector options?
20ppm is better than the average DSLR, and better than a lot of other cameras that aren't Lockit'ed.
We did our homework on the Lectro, the top plate has a couple of switches on it (inside). When sitting passively between Lav and Tx, there is no difference, but for providing power stand-alone, one position works with original non-servo mics, and the other position works with universal and servo bias wired Lavs.   We've been testing with both.
I expect that the advice you'd get from anywhere would be to re-wire old mics to universal wiring anyway...
One of the Lectro 152 mics I got turned out to be a 150 with just the label changed (they are the same capsule) - took us a while to figure out it was original wiring.
Nice job guys. Great product and price point.
Should work fine, I'm not personally familiar with the Sony pin assignment.
Hi,
We'll consider the Lemo, does everyone wire those the same?
The Senn 3.5mm is lockable, already tested. The through cable it comes with is also lockable connectors on both ends.
Tom (TASCAM)
If this thing had timecode, it'd be a killer. You should talk to Tentacle Sync for the MKII.
And I too second the opinion that there should be a 3 pin lemo adapter. In Sweden, 95% of the time the wireless system is either Wisycom Lemo or microdot. Always DPA lavs. I can't see Microdot happening on this little machine, but it would make sense somehow sizewise.
Great product nonetheless! You'll sell a bunch I reckon.
Yeah I opened the tentacle sync to see what's inside. The PCB is about 2x2 CM, that could fit anywhere.
Saw this unit at AES and it looks good - very small. I was impressed after talking with Tom Duffy about it - they have done their homework on the inputs.
Hey Tom, I've been bugging Sound Devices for something like this for years. Great tool for Wireless Booms on Film/TV sets where our chances for drop outs are getting more frequent.
So my couple questions....
  • Whats the record time per GB
  • Can you turn off the "Backup Track" to get more record time
  • What happens when you get to the end of the card, i.e. will it "Loop Record" like the Zaxcom or just stop recording
Thanks again, I hope to convince the Mixer I work with to get a couple for the Boom Ops
Andy
Andy: " Whats the record time per GB "
that one is easy:
the recording time per GB is the same for all devices when recording industry standard .wav (aka bwf) files.
The DR-10 is indeed an analog split of the input signal, so no delay and no interruption on battery end.
Official battery life:
Alkaline 10 hours
Eneloop Pro 8 hours
Energizer Ultimate Lithium 15.5 hours
Mono files are recorded.   In dual mode you get 2 mono files, and half the capacity.
At media full, recording stops.
Tom (TASCAM)
that one is easy:
So, once again, you provide no useful information.
If I remember correctly (and someone correct me if I'm wrong)...I think recording time per gb is about an hour of 2 tracks bwav at 48Khz 24bit.
"I think recording time per gb is about an hour of 2 tracks bwav at 48Khz 24bit."
.. Or approx. 7.6MB per track minute  (455MB per track hour)
Sorry Senator, we probably should have let the lazy folks figure it out for themselves.
