How much is the working voltage of zaxcom erx2tcd? Product manual can not find, only to see can use lithium battery. Do not know whether the use of two 3.2 volt lithium rechargeable battery two is 6.4 volts.
Powerex, Imedions etc in decent condition will last well over 12 hours. I have some Powerex AAs that are probably 4 or 5 years old, were mostly used in transmitters, and they'll last a full day in an ERX2. I usually don't turn them off for lunch just to be sure nobody forgets to power them up if they rip off to get a shot, and don't have problems with them running out of juice.
If you need some serious run time, then maybe disposable lithium batteries give you more. No idea what kind of time that gives you.
  • 4 weeks later...
