Redesigned FUZE Ti Timecode Slate!
George Tsai
anyone try with Fuze Ti slate with Zaxcom ERX2TCD?
Success (use same TC cable):
Zaxcom Nomad 12 (TC in/out) (connect in one second).
No Success (use same TC cable):
Denecke GR-2 (sometimes jam 2 to 3 times until success, the hour digi fail, need connect in 7-10 second).
Zaxcom ERX2TCD (fail)
  • Replies 79
  • Created
  • Last Reply
Top Posters In This Topic
Great to hear Michael:-) I do have to note that it does not automatically detect the frame rate, if you're powering up the slate with a timecode signal already connected it will use and display the last frame rate setting before syncing. That is just as a reminder of the last used frame rate, the slate saves the last frame rate used in the internal flash memory. I tried to code for automatic frame rate detection but just could not get it to reliably differentiate between 23.98 and 24.00 or 29.97 and 30.00.
Good to know. I was only switching from 23.97 to 29.97 and I remember it detecting  and jamming to whatever I set the master clock to. I'll have to play with it again when I get home.
  • 1 month later...
I made a couple extra slates during the short production run and they are available on the site:-) Bundled http://fuzeti.com/compact-bundle-239.html or just the generator display by itself http://fuzeti.com/fdcpp.html :-) The enclosure and final assembly will take approximately two weeks from the time of order to ship:-)
Edited by piman
