Mikko Kolehmainen Posted January 16, 2015 Report Share Posted January 16, 2015 I'm going to buy a better field recorder to do more ambient recordings and SFX-work. There should be at least 6 XLR inputs, 96 kHz sample rate and nice limiters (or neverclip). I've been thinking about Zaxcom Nomad, but is it true it has LPF and it's not possible to record with flat freq response? I'm going to be using mostly Schoeps MS, DPA 4061s, Line audio CM3s, several contact mics and hydrophones. Possibility to record DMS, Quad and 5.1 easily would be nice too. So works from very quiet to really loud, in hot and humid and cold and dry locations. What recorder you would use and why? Quote Link to comment Share on other sites More sharing options...
glenn Posted January 17, 2015 Report Share Posted January 17, 2015 A while back I posted the frequency response of Nomad. It is very flat without the High pass on. Maybe some one can dig up the plot I posted. Neverclip and the Nomad would be an excellent choice. Glenn Quote Link to comment Share on other sites More sharing options...
jdutaillis Posted January 17, 2015 Report Share Posted January 17, 2015 I'd recommend a 788t-SSD for certain. Quote Link to comment Share on other sites More sharing options...
Mikko Kolehmainen Posted January 17, 2015 Author Report Share Posted January 17, 2015 A while back I posted the frequency response of Nomad. It is very flat without the High pass on. Maybe some one can dig up the plot I posted. Neverclip and the Nomad would be an excellent choice. Glenn Thank you Glenn, I saw the plot, but it just confused me because in Nomad's manual it says that frequency response is 50Hz-22kHz. Quote Link to comment Share on other sites More sharing options...
Constantin Posted January 17, 2015 Report Share Posted January 17, 2015 Thank you Glenn, I saw the plot, but it just confused me because in Nomad's manual it says that frequency response is 50Hz-22kHz. What's the confusion? A recorder's frequency response can be flat and range from 50Hz-22kHz. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted January 17, 2015 Report Share Posted January 17, 2015 Do you need to record a lot of sound with a lot of content below 50Hz? Just because the Nomad (or etc) isn't FLAT below 50 doesn't mean it won't record sound at those lower freqs... philp Quote Link to comment Share on other sites More sharing options...
mikewest Posted January 18, 2015 Report Share Posted January 18, 2015 Post can bring the lows up if you are recording a volcano, explosions or space rockets!!! mike Quote Link to comment Share on other sites More sharing options...
Mikko Kolehmainen Posted January 18, 2015 Author Report Share Posted January 18, 2015 Oh yes, sorry, I misread. In Manual-pdf there was frequency response 50Hz-22kHz (48kHz) and in product site 20Hz-22kHz (38kHz). I read that they both were at 48 kHz. Even though I think it would be clearer to say that that frequency response is what it is with this kind of roll of starting there with this kind of slope... Nomad seems to be really a great choice also for this kind of work. Is there possibility to link multiple Nomads? Or Nomad and Maxx? Glenn, would it be possible that some day ZaxConverter could work natively on Linux as well? Quote Link to comment Share on other sites More sharing options...
glenn Posted January 18, 2015 Report Share Posted January 18, 2015 Zaxconvert is for PC and Mac. Linux is not a possibility unless it just happens to work with one of the current versions. Since Nomad can record up to 12 tracks I do not think you would need to link multiple units together. In any case sample clocks are very accurate but can not be locked together. Glenn Quote Link to comment Share on other sites More sharing options...
Miles Anderson Posted January 19, 2015 Report Share Posted January 19, 2015 just use wine to run something in "windows": https://www.winehq.org Quote Link to comment Share on other sites More sharing options...
dfisk Posted January 19, 2015 Report Share Posted January 19, 2015 If you need to use multiple nomads (which I can see doing, as I did the multiple recorders back in the Deva II days) just have them all running the same TC and then you can spot the files right into pro tools. They'll line right up. I also slate each take, even for sound effects, if I have multiple machines running just as a backup in case the TC gets wonky. That way you can line it up old school style. Yes...that means have a clapper or some sort of sharp sound that spikes the wave form. If you are going to be recording 5.1, then a machine with at least 6 mic inputs is a must. All the high end machines that have these are all really good, and it just comes down to personal preference as to which one you'd want to use. Quote Link to comment Share on other sites More sharing options...
