olphi Posted February 9, 2015 Report Share Posted February 9, 2015 Hello, i m shooting a multi caméra situation with some cameras are rolling at 25 FPS and others in 50 FPS. What is the best practice for sync? I m recording with my SD664 and Ambient ACL 201 TC box. There is only 25 FPS on the Ambient TC logger. I thought to make a clap but maybe is there a better solution? Best regards. Quote Link to comment Share on other sites More sharing options...
VASI Posted February 9, 2015 Report Share Posted February 9, 2015 25 Quote Link to comment Share on other sites More sharing options...
olphi Posted February 9, 2015 Author Report Share Posted February 9, 2015 OK 25 for the SD 664 but is it possible to sync the 50 FPS cameras with the Ambient ACL 201? Do I have to sync all the TC box with my SD664 and then output TC via the BNC with 2 différents FPS? Sorry but I m lost. Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted February 9, 2015 Report Share Posted February 9, 2015 50 fps cams don't need sync for sound. Will later be played at 25 anyway. Will be used for slo-mo only, won't it. Oh, maybe it won't, and they drop every second frame in post. It's a trick done on some commercials to be able to go to slo-mo whenenver they like. If that's the case: Check with cam dept if their cams are able to cross jam to an incoming 25 fps TC. Depends on cam model. Or get / rent a newer TC box that supports double frame rates. Quote Link to comment Share on other sites More sharing options...
olphi Posted February 9, 2015 Author Report Share Posted February 9, 2015 Thanks Peter. It will be sony F55 caméras. What TC sinc box can do double frame rate? Quote Link to comment Share on other sites More sharing options...
jason porter Posted February 9, 2015 Report Share Posted February 9, 2015 25, you'll be fine. Quote Link to comment Share on other sites More sharing options...
