millar Posted April 1, 2015 Report Share Posted April 1, 2015 Hey all, So my 664 is acting up again. I am gettin corrupt files on the SD card that show up with zero bytes as the file size on the SD but on the CF there is a file with actual data in it. Recording multiple mono. Sometimes it is only one stem on the SD of the multiple mono file that is affected by the zero bytes issue. I thought that I had a bad card which went out of the rotation but the problem has persisted on multiple cards using approved media (Sandisk 64BG CF Extreme Pro 95MB/s). I am also noticing now that the date modified is different between the CF and SD cards (although the actual timecode is correct on files written to both CF and SD) with a difference of exactly 1 hour between them. The CF will have a date modified that is in line with the TOD TC but the SD is exactly one hour slow on the date modified from the TC written in the metadata. Anyone have any problems remotely close and found a solution? Millar Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted April 1, 2015 Report Share Posted April 1, 2015 Millar, Have you tried any smaller size SD cards or a different brand? It could be that the SD slot has a hardware issue that needs to be fixed. Quote Link to comment Share on other sites More sharing options...
ProSound Posted April 1, 2015 Report Share Posted April 1, 2015 What firmware are you on? Does it record Poly Wav ok? Quote Link to comment Share on other sites More sharing options...
millar Posted April 1, 2015 Author Report Share Posted April 1, 2015 I am running the most recent firmware and no, I have not tried smaller SD card sizes. I am using cards from the Prod Co. that I am doing the job for. I never had this issue before with my own cards so my inclination to to blame the cards (especially since it seems to be multiple cards which are all exactly the same size, brand and speed). I will try my Sandisk extreme Plus 32GB 80MB/s tomorrow and see if it helps. It is a pretty frustrating problem as I have to Google drive the files over the follwoing day when it happens and I dont want to make a name for myself with post for data problems. Poly wav have always been fine in the past, specific request from post for .wav mono Quote Link to comment Share on other sites More sharing options...
afewmoreyears Posted April 1, 2015 Report Share Posted April 1, 2015 What stands out are the "Companies cards"... You are NOT the buyer, you don't know where they came from or how old they are....if they have been super heated or dropped.... and a few other things.... Also .... I don't swap cards between machines... but recently I did between a 788 and a 633... with a new computer format in between... No issues.... but... I like to keep cards for specific machines... and I like total control over those cards... as the situation will permit.. As you say, try YOUR cards.... controlled by you.... I bet they work fine... Pre format in your computer before your machine format... Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 1, 2015 Report Share Posted April 1, 2015 +1 re cards. Unfortunately MT file recorders are not like DSLRs, and using just any card in just any condition is not a good idea. I only use cards I've kept track of and formatted and tested myself. Any other way is trouble, and more tracks at higher sample rates is more trouble. philp Quote Link to comment Share on other sites More sharing options...
MT Groove Posted April 1, 2015 Report Share Posted April 1, 2015 Beware of fake Sandisk cards. There are plenty of those floating around. I have came across those a while back and they never worked properly on the 664. Luckily I was able to get a refund from the seller. Sammy Huen Quote Link to comment Share on other sites More sharing options...
Ty Ford Posted April 7, 2015 Report Share Posted April 7, 2015 +1 with cards and formatting freshly. Regards, Ty Ford Quote Link to comment Share on other sites More sharing options...
joy Posted April 15, 2015 Report Share Posted April 15, 2015 The same thing happened on me. For about a year. Changed a lot of SD card, and no improvement. Fortunately, CF card without problems. Quote Link to comment Share on other sites More sharing options...
ninjafreddan Posted April 17, 2015 Report Share Posted April 17, 2015 I only use (unknown) production SD cards if I'm really asked to - for fast delivery after a day of shooting. But I always record on my own CF card too, and make a backup that I keep until the show airs. :-) Never lost a file so far. *knock on wood* Cheers Fred Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted April 17, 2015 Report Share Posted April 17, 2015 When production hands me their card, I still record on mine. At the end of the day, I pop one of my cards out, theirs in, and use "copy directory to SD (or CF)". Quote Link to comment Share on other sites More sharing options...
