Eric Toline Posted April 1, 2015 Report Share Posted April 1, 2015 April, 2015 - Las Vegas, NV, NAB 2015 -- Lectrosonics is introducing the smallest full-featured UHF bodypack microphone transmitter available - the SSM (Super Slight Micro). Part of the Digital Hybrid Wireless® Series, the SSM is fully compatible with all current Lectrosonics receivers including the UCR411A, SR Series, L Series, and Venue Series, along with several older models via compatibility modes. The SSM features a wide tuning bandwidth of three standard Lectrosonics blocks or up to about 76 MHz depending on the specific frequency range. RF power is selectable at 25 or 50 mW for flexibility in various applications. Dimensions for the SSM are 2.52 x 1.48 x 0.57 inches or 64.25 x 37.6 x 14.5 mm, and weight is 2.3 oz or 66 grams, including battery. The SSM is available on four different frequency ranges for worldwide use: A1 (470.100 - 537.575 MHz or blocks 470, 19 and 20), B1 (537.600 - 614.375 MHz or blocks 21, 22 and 23), C1 (614.400 - 691.175 MHz or blocks 24, 25 and 26) and D1 (for export only, 691.200 - 767.975 MHz or blocks 27, 28 and 29). Tuning steps of 100 or 25 kHz can be selected in the menu, allowing for up to 3,072 frequency choices, depending on the band. The SSM features an all-metal housing and uses the rugged, industry standard Lemo 3-pin microphone connector common to other bodypack transmitters used extensively in theatrical and TV applications. Thus, existing lavaliere and headworn microphones already terminated with this connector can be used with the SSM without an adapter. Different bias voltages and termination impedances can be selected via the transmitter's menu for optimum performance with a wide range of microphones. Pre-set values for several microphones are included as menu choices for DPA, Countryman B6/E6, Sanken COS-11, Sennheiser MKE1/MKE2, along with standard dynamic microphones and line-level input sources. An infrared sync port on the SSM allows for quick setup with compatible receiver systems. A backlit LCD allows for ease of setup in any lighting conditions. A micro-B USB port makes it possible for firmware updates in the field as advanced features are added in the future. The SSM responds to remote commands for frequency, audio level, sleep modes and other settings from the RM remote unit or 3rd party smartphone apps. The hardened, stainless steel belt clip can be securely attached or easily removed without tools. The SSM is powered by an included 3.7v rechargeable lithium-ion flat pack battery. "The demand for an ever-smaller bodypack transmitter has been with us for years." states Karl Winkler, director of business development for Lectrosonics. "The only way to make a full-featured unit smaller than the SMV was to change the battery type and the microphone connector. We chose the Lemo 3 because it is small, rugged, reliable, and already an industry standard. The battery was chosen for its availability, size, shape, and reasonable run time. All in all, the SSM is a really exciting product for us and we appreciate all the ideas and suggestions we've received from our customers pushing us in the right direction with this product." Price for the SSM MSRP: $1,998, Availability in Q3, 2015. Quote Link to comment Share on other sites More sharing options...
Shastapete Posted April 1, 2015 Report Share Posted April 1, 2015 Quote Link to comment Share on other sites More sharing options...
Brian Maier Posted April 1, 2015 Report Share Posted April 1, 2015 I know its April 1st and all, but I see no reason that this couldn't be real. Is that the joke... Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted April 1, 2015 Report Share Posted April 1, 2015 Either Lectro's level of commitment to a prank is unparalleled, or this is for real: http://www.lectrosonics.com/US/phocadownload/SSM_manual.pdf Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted April 1, 2015 Report Share Posted April 1, 2015 If there's something obviously saying "joke", I missed it. Even a few years ago Lectrosonics floated the idea of ditching the TA5 for something smaller. They have also said the AA battery is a roadblock to some things they want to build, and achieve good run times. Seems totally plausible! Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted April 1, 2015 Author Report Share Posted April 1, 2015 Trust me on this. It's absolutely real. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted April 1, 2015 Report Share Posted April 1, 2015 They usually put the ''april 1st announcement'' on their front website page; this one isn't. Still waiting for the prank..! Oh I get it now: no prank this year... which is the prank Brian, you might be right ! Quote Link to comment Share on other sites More sharing options...
Boomboom Posted April 1, 2015 Report Share Posted April 1, 2015 Three blocks in a case +or- the size of an SMV; wow...! Quote Link to comment Share on other sites More sharing options...
LarryF Posted April 1, 2015 Report Share Posted April 1, 2015 Just this year's prank. http://www.lectrosonics.com/US/Press-Releases/lectrosonics-introduces-the-ssm-super-slight-micro.html Best Regards, Larry Fisher Lectrosonics Quote Link to comment Share on other sites More sharing options...
ShubiSnax Posted April 1, 2015 Report Share Posted April 1, 2015 Ahh yes the 3d eraser! Why didn't I think of that? Quote Link to comment Share on other sites More sharing options...
Jeff New Jersey Posted April 1, 2015 Report Share Posted April 1, 2015 Tough to be a manufacturer now a days, we expect anything is possible Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted April 1, 2015 Report Share Posted April 1, 2015 Removing every other atom was quite the trick. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted April 1, 2015 Report Share Posted April 1, 2015 aaarg...! that was indeed too early after the L series to come with that... Quote Link to comment Share on other sites More sharing options...
Solid Goldberger Posted April 1, 2015 Report Share Posted April 1, 2015 I'm so confused... e. Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted April 1, 2015 Report Share Posted April 1, 2015 Three blocks in a case +or- the size of an SMV; wow...! very much minus an SMv. Quote Link to comment Share on other sites More sharing options...
soundtrane Posted April 1, 2015 Report Share Posted April 1, 2015 bah. it's actually even smaller... Quote Link to comment Share on other sites More sharing options...
Karl Wasserman Posted April 1, 2015 Report Share Posted April 1, 2015 Now incorporating new Hybrid SuckerFish™ technology! Quote Link to comment Share on other sites More sharing options...
Jason Todd Posted April 2, 2015 Report Share Posted April 2, 2015 I'm also confused. Quote Link to comment Share on other sites More sharing options...
Jason Meadows Posted April 2, 2015 Report Share Posted April 2, 2015 http://www.trewaudio.com/store/Lectrosonics-SSM.html Quote Link to comment Share on other sites More sharing options...
