Scott Selman
Rechargeable Batteries for TX
A few points about the tubular style battery holders with the teeth that shred the outer casing of the battery.
The reason I use them, despite their destructive nature, is 'cause they are way more convenient to grab a single battery with one hand, while moving fast on a doc shoot- I can't use a battery case with a lid that holds 4 batteries- that's a recipe for 3 batteries on the ground and one in my hand... Also they are great for showing you which batteries are charged or not depending on which end is stuck in the case.
But they sure make a mess of the wimpy plastic sheath that rechargeable batteries are wrapped in... which can lead to dead shorting batteries in some (badly designed) metal lined battery compartments, or, more likely,  bits of plastic sheath covering the end terminal and interrupting current flow, or just bunching up and making it hard or bloody impossible to get the batteries out of the device they are in.
To deal with the problem of the jaggedy battery tube:
First, you can dremel or cut the "tooth" to be smoother and not as big or abrasive- be careful about cutting too much off, since it will let the battery fall out.
This lets you do the one handed battery change, although it is still possible to do damage to the battery over time, 'cause there is still some friction.
The other trick is to bend up the "tooth" (which is on a flexible tab) with a fingernail of the opposite hand that is grasping the battery while inserting or extracting it.
It's not too difficult, though it takes away the ability to do a one handed battery exchange.  This is the way I do it when changing batteries in a non hurried fashion at the beginning of the day or lunch...
These might be super obvious tricks to some of you all- but it took me a while to figure them out, and a lot of damaged battery casings, so I though I'd share,
especially since it's often the tiny things that can make a big difference...
Brent Calkin
23 hours ago, Daniel Ignacio said:
Also RED ALERT, IKEA LADDA 2450 batteries are now available for purchase online. Surprised they haven’t wisened up and increased the price as well.
OHHHHHHHHHHH......... I guess that means folks like myself who live in a country without IKEA can now order them
I thought it was time for a review of my KentLi Li-Polymer batteries after three years of use. The average usage has been twice a week for three years or around 300 times each. Of the 48 batteries I have, the first two have failed, one cell failure and one regulater failure. The remaining batteries seem to still be in good condition. I like the KentLi batteries because I can measure both the voltage of the cell and the regulated 1.5 volts. They have three accessible terminals, one negative and two positive.
I haven't experienced the high-pitched sound mentioned  elsewhere and overall I'm happy with these batteries. On the other hand, I would guess that NiMh Eneloop Pro's would perform equally well.
On 4/9/2019 at 4:58 AM, Daniel Ignacio said:
Amen to this.
Very good batteries.
Ikea Ladda does not hold up against Eneloop Pro and Powerex
Every ikea Ladda I had was discarded by my maha charger a lot quicker then ENELOOP Pro.
But You get what you pay for.
Not my experience. Eneloop Pro and Ladda compare very favourably, and the Ladda covering doesn't seem to crack as much at the edges as the Eneloop Pro. I also always use slow charge on all rechargeables.
Edited by Jim Rillie
added thought
54 minutes ago, Jim Rillie said:
[snip}  I also always use slow charge on all rechargeables.
Hi Jim,
Good suggestion. Fast charge (1 hour or less) is particularly hard on high capacity NiMh batteries. Eveready used to have a 15 minute charger. It not only destroyed 2700 mAh PowerEx batteries in just a few recharges, it wore out the Eveready batteries in about 10 recharges. The self discharge rate increased to half discharge in a just a few days.
Best Regards,
Larry Fisher
+1
I have been quite happy with the AA Ladda 2450 for more than a year now, and while I can't claim to have done any structured testing, I haven't noticed any variance.
I have some of the Ladda 2450 AA batts, and have not 'noticed' a difference with my Enloop Pros. I do not have a fast charger. As I understand, fast charging reduces the number of charge/discharge cycles.
My experience with the casing is the opposite. Ikea ladda break easier in my opinion.
3 hours ago, Rick Reineke said:
I have some of the Ladda 2450 AA batts, and have not 'noticed' a difference with my Enloop Pros. I do have a fast charger. As I understand, fast charging reduces the number of charge/discharge cycles.
There has to be a big difference in quality. As soon as my maha smart charger tells me to discard a battery I try to do factory restore and if that does not work I toss it. Ikea ladda and amazon rechargbles last a lot less then eneloop. If I need batteries for slates, erx and house appliances I use the regular eneloop which last forever and are cheaper then pro.  And the price difference does not make me use inferior battery.
