jonathan chiles Posted May 13, 2015 Report Share Posted May 13, 2015 I am wanting to add another SRb to my kit which will sometimes be in the bag and sometimes on a camera. The SR battsled is a very neat solution for powering the SR on dinkycams but somewhat pricey. Can anyone reccommend a manufacturer that makes a decent Sony battery mount plate that converts the 7.2V up to 12V? I want something cheap but not nasty that I can dual lock onto the SR when I need it. Quote Link to comment Share on other sites More sharing options...
Derek H Posted May 13, 2015 Report Share Posted May 13, 2015 You'll regret not getting the Lectro battsled I suspect.. But there are many plastic sleds available on BH for example and I don't think you need voltage regulation actually. Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 13, 2015 Report Share Posted May 13, 2015 Hi Jonathon, Lectro website answers all: http://www.lectrosonics.com/US/phocadownload/srb5p_srb_td.pdf You don't need to step the 7.2 Volt up to 12 Volt. The unit will operate somewhat below the specified low Voltage limit of 6 Volts. Best Regards, Larry Fisher Lectrosonics Quote Link to comment Share on other sites More sharing options...
jonathan chiles Posted May 13, 2015 Author Report Share Posted May 13, 2015 Thank you gentlemen! More homework I need doing Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 13, 2015 Report Share Posted May 13, 2015 Thank you gentlemen! More homework I need doing My grin of the day. LEF Quote Link to comment Share on other sites More sharing options...
ShubiSnax Posted May 13, 2015 Report Share Posted May 13, 2015 I use two of these wired together to power my SRb when there is no power source on the camera rig. Two iPower 9v's will last me until lunch. http://www.ebay.com/itm/like/301575514680 Quote Link to comment Share on other sites More sharing options...
atheisticmystic Posted May 13, 2015 Report Share Posted May 13, 2015 Maybe Wielage will post his SR set-up: a velcro'd chinese battery that works quite well. best Quote Link to comment Share on other sites More sharing options...
jonathan chiles Posted May 14, 2015 Author Report Share Posted May 14, 2015 Indeed gents I have had an "ugly" solution for some time which is a 2200mAh 3 cell LiPo velcro'd on the side. I have a low voltage cut off inline to stop the battery doing a deep discharge. I also went Shubi Snax route and obtained 2 x 9V plastic holders and glued them together side by side and wired them in parallel to a 2.1mm plug and again velcro'd it to the side. I thought this was very smart.. but found that it ran the SRb for only a couple of hours. More testing maybe.. also thanks for bringing up "Chinese" batteries must be loads on ebay with a slim form factor that would work. Quote Link to comment Share on other sites More sharing options...
