Need to re sign in every time I go to page.
ILavLA
Jeff
I need to re sign in every time I go to page.
When I do it says the password is wrong.  Then I go through the forgot password process, set a new password,
It works for a while and then the next day it makes me go throught the whole process again.
Am I the only one having this problem?
Thanks Jeff and have a great day,
John Lifavi
Make sure your browser is not auto-filling the old password. Be sure the password you are entering is the one you want to use (the change password routine doesn't always work properly). Remember as well that you have to use your Display Name to login now. Your Display Name is: ILavLA.
If you continue to have trouble you should contact me directly and I will help. If you are able to contact me using the message system on site that will be fine or email me at:  jw@jwsoundgroup.net
