Malcolm Davies Amps CAS Posted June 17, 2015 Report Share Posted June 17, 2015 Jeff, Could you point me in the right direction as how I delete PM's please. I don't seem to find the necessary menu. many thanks. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted June 17, 2015 Report Share Posted June 17, 2015 I'm not sure of how to delete all the PMs in the inbox in one shot, but if you open the message and click "Options" there is a 'Delete' option per message. OTOH, (and I have not tried it), If you click your user name (top right) and go to 'Content- Messages', click the 'gear' icon, next to 'My Conversations' there is a 'Empty' option. I would assume that empties the inbox. Again, I have not tried this. I'm sure Jeff will elaborate in any case. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 19, 2015 Report Share Posted June 19, 2015 I've found the "Options" selection isn't offered on my older messages. The available method to clear out my IN BOX seems to be the EMPTY option. I'd like to be able to selectively delete many older messages, but there doesn't appear to be a way to do it without clearing the whole thing. Since the changeover, my Messages show I'm over capacity at 105% so it won't allow me to send or receive any messages. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 19, 2015 Report Share Posted June 19, 2015 I will look into the Messages routine as it is done now. It has changed and I haven't really gotten up to speed on all the ins and outs. I did set global preferences to ignore message quotas so even though it is reported that you are over the quota it should still function (maybe not). Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 19, 2015 Report Share Posted June 19, 2015 If I click on Compose a Message I get the following notice: "Your inbox is full. You must delete some messages before you can send any more" Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 19, 2015 Report Share Posted June 19, 2015 Well, I looked into how Messages is working now and there have been lots of changes. When you click on the Messages icon you get a list and you can Go to Inbox which opens a full page dedicated to Messages. If you want to delete individual messages rather than using the global Empty command, it looks like under Options you can delete messages but only your own, not ones that arrived from other members. Weird. The other thing that is odd is that I have set it so that the quota limit is in place but it will be over-ridden. I think there is a setting I need to increase that allows you to STORE a greater number of messages. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 21, 2015 Report Share Posted June 21, 2015 I still can't compose messages (and I haven't received any since the new software was installed). It looks like I may need to completely delete everything to use messages again. Unfortunate, as there is some info in some of them I had hoped to hang on to. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 21, 2015 Report Share Posted June 21, 2015 I'm going to try and get to the bottom of this, John. I'm still trying to figure out what has changed (and evidently not for the better) with the Messages system. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 21, 2015 Report Share Posted June 21, 2015 Thanks for your hard work with the site, Jeff. Please know that it is much appreciated. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 21, 2015 Report Share Posted June 21, 2015 I hope out of my elation I'm not reporting too quickly, but, thanks to Jeff's diligence, the message system seems to be working now. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 21, 2015 Report Share Posted June 21, 2015 I cant delete old messages either. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 21, 2015 Report Share Posted June 21, 2015 Yes, but you should be able to send and receive now, which is much more important. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 21, 2015 Report Share Posted June 21, 2015 Okay, here's the lowdown: Messages has become much more comprehensive, feature rich and super complicated, non-intuitive and very confusing. I'm not going to try and outline all the things I discovered while mashing around the Inbox but I will mention a few. Once you're in the Inbox, if you click on a message there are several things you can do (easily deleting isn't one of them). It looks like you cannot delete your OWN message but the reply message can be deleted using the "Options" drop-down. You can also mark everything "As Read" (though I don't know what that gains you). I also noticed that you can make a "New Folder" which I did and called it "Archive". Then, using the folder icon in the right hand corner, you can "Move" messages to this new Archive folder. Again, I don't know what use this is beyond simple organization. To make full use of the new and incredibly cumbersome Messages I would probably have to make a "How To" video tutorial and that is not something I'm going to do. Quote Link to comment Share on other sites More sharing options...
