seth Posted June 20, 2015 Report Share Posted June 20, 2015 Hi Folks Just Got a Tig Ql this morning from Location sound corp. I would call manufacturer but it's Saturday morning as i write this. Same cables, i can jam the tig from my slate but not from the 664. Tired all settings on tig. I can also jam slate from 664. I can jam 664 from Tig. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted June 20, 2015 Report Share Posted June 20, 2015 Level at "0"? Quote Link to comment Share on other sites More sharing options...
seth Posted June 20, 2015 Author Report Share Posted June 20, 2015 Yup. Quote Link to comment Share on other sites More sharing options...
syncsound Posted June 20, 2015 Report Share Posted June 20, 2015 What cables are you using? Quote Link to comment Share on other sites More sharing options...
seth Posted June 20, 2015 Author Report Share Posted June 20, 2015 (edited) Sound devices xl-lb2 and custom Location sound Corp cables. I can jam the slate from the from the 664 and the Tig from the Slate Can Anyone else confirm jam Tig from 664? Thanks Edited June 20, 2015 by seth Quote Link to comment Share on other sites More sharing options...
syncsound Posted June 20, 2015 Report Share Posted June 20, 2015 (edited) I use TIGs with my 664. The one thing I've found is that you have to tie pins 1 and 3 together somewhere in the chain. A fully balanced cable won't jam the TIG. I use the Sound Devices Lemo to dual XLR cable, and an FXLR to TS unbalanced 1/4" adapter. Edited June 20, 2015 by syncsound Quote Link to comment Share on other sites More sharing options...
Boomboom Posted June 20, 2015 Report Share Posted June 20, 2015 Supposed to be 1/8"sleeve-BNCsleeve / 1/8"tip-BNCpin. Mine work that way with a 633 Quote Link to comment Share on other sites More sharing options...
seth Posted June 20, 2015 Author Report Share Posted June 20, 2015 I use TIGs with my 664. The one thing I've found is that you have to tie pins 1 and 3 together somewhere in the chain. A fully balanced cable won't jam the TIG. I use the Sound Devices Lemo to dual XLR cable, and an FXLR to TS unbalanced 1/4" adapter. Thanks thats what I needed. Didn't see that in any documentation. Quote Link to comment Share on other sites More sharing options...
syncsound Posted June 21, 2015 Report Share Posted June 21, 2015 To my knowledge, it isn't documented. I found that out by trial and error when I wrote a review of the TIG. My experience mirrored yours: I could jam from the slate, but not from the 664. I swapped out adapters until I made it work. Quote Link to comment Share on other sites More sharing options...
