Bartek Posted October 20, 2008 Report Share Posted October 20, 2008 Gentelman, I once again seek your council. I recently purchased a MK4 on ebay. All went well and I received the capsule, one problem the serial # is inked out! I will send the capsule to redding audio to see if they can un-ink that # and get me history of that capsule. Would there be any other reason why someone would try to obscure the # other than for the obvious reason? if there is anyone who had their "borrowed" recently please let me know. Bartek Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted October 20, 2008 Report Share Posted October 20, 2008 I'd also ask Redding if they can test the capsule for you. Performance or lack of might also be a reason for an obscured SN. Philip Perkins Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted October 20, 2008 Report Share Posted October 20, 2008 Gentelman, I once again seek your council. I recently purchased a MK4 on ebay. All went well and I received the capsule, one problem the serial # is inked out! I will send the capsule to redding audio to see if they can un-ink that # and get me history of that capsule. Would there be any other reason why someone would try to obscure the # other than for the obvious reason? if there is anyone who had their "borrowed" recently please let me know. Bartek Inked out with a Sharpie or the like? Then you should be able to remove the "ink" with paint thinner or WD40 or such if the # is engraved into the case. Eric Quote Link to comment Share on other sites More sharing options...
cmgoodin Posted October 20, 2008 Report Share Posted October 20, 2008 Sharpie Ink comes off with plain old Rubbing alcohol. And it is less corrosive than Acetone (paint remover) or other solvents. ----Courtney Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 20, 2008 Report Share Posted October 20, 2008 Inked out with a Sharpie or the like? Then you should be able to remove the "ink" with paint thinner or WD40 or such if the # is engraved into the case. On a Schoeps capsule, the number is written in ink on the plastic disk up inside the capsule (looking in from the threaded end). Perhaps applying paint thinner, WD-40 or a blowtorch to the inside of a Schoeps capsule might be ill-advised. JB Quote Link to comment Share on other sites More sharing options...
