Mikisuke Shimadzu Posted July 15, 2015 Report Share Posted July 15, 2015 Hello, everyone.I'm searching for the best way to solve the sync issue of the field recorder match in Pro Tolols.After this matching process, always there are very small random gaps between the editor's AAF/OMF tracks and my field recorder tracks. It's nervous, though they are very small gaps (2 frames or less).Today, I made some tests using Fix Sync of Titan4.This is my first experience of Titan. And Titan is 14days trial mode.To be honest, I was very impressed by Fix Sync. It's very easy and precise.But I have one question.In my test, Fast Align mode was pretty accurate. The result was in error by less than 3 samples.But, Sample Accurate Mode was much more inaccurate than Fast Align mode!Still more, the longer Search Length, the less accurate.What's going on with this Sample Accurate Mode?It seems that Fast Align mode is more accurate than Sample Accurate Mode...or I made some mistakes?Is there anyone who knows about this? Quote Link to comment Share on other sites More sharing options...
Mikisuke Shimadzu Posted July 16, 2015 Author Report Share Posted July 16, 2015 I've recieved a message on this matter from Synchro Arts.Here's this. The sample accurate mode is more sensitive to variations between the two signals- which can cause it mis-alignment.The Fast Align mode should be accurate to about 6 samples.In most causes the Fast Mode is the best option.You should keep the search length as short of possible – longer lengths increate the search time and increate the possibility of a mis alignment. Quote Link to comment Share on other sites More sharing options...
