Real world SM battery life
Jeremiah Sheets
Considering the Lecro SM for a small and inexpensive TX, but I'm concerned about life on a single AA.
I believe Lectro mentions around 3.5 − 4 Hrs on a 2200 mAh NiMH. I'm running 2500 Eneloop Pros. Anyone have any real world battery ratings for the SM with a similar battery? 4 hours won't cut it for me. If that's pretty accurate, I'll have to go with one of the 2-battery options.
Thanks.
Jason is right.
On an episodic TV show or feature, we change out the Imedion or black Eneloop NimH AAs at the 3hour mark - subs time in the morning,
and at 3 hours in in the afternoon.
Not a big deal for us, considering the hide ability and ruggedness of the MMs or SMa, SMVs.
Regards,
Jim Rillie
I have low serial number, first generation SMs, and even the big Powerex batteries fit. I started using rechargeable batteries in them long before there were all these choices, and only on a rare occasion or two did one get stuck. Easy enough to remove once it cooled off.
Given the choice of a more standard size rechargeables like Eneloop, batteries getting stuck is simply a non issue.
Using rechargeables should be standard practice, with lithiums going in only when necessary. It's irresponsible to do otherwise.
Lecture from the old guy over.
I also typically use rechargeables and get a little more than 3.5 hours continuous use. But if you're diligent about sleeping the transmitter inbetween setups, you can stretch this out to 6 hours on scripted sets. For docos, live work, or critical interviews, I'll just use Lithiums so as not to take a chance on failure across 5 continuous hours. The SMQVs and the newer 2xAA L-series transmitters will go a lot longer.
