Rafael Posted September 13, 2015 Report Share Posted September 13, 2015 Hi all,Anyone have an idea of what's wrong with these um200c ?I'm too far from Lectrosonics inc. to send these unitThe shipping price will be expensive and close to the price of an used oneI'm from Uruguay South America maybe a technician can repair it here?Sorry for my English Thanks Quote Link to comment Share on other sites More sharing options...
ProSound Posted September 13, 2015 Report Share Posted September 13, 2015 What does it sounds like with a microphone attached with someone speaking in it Quote Link to comment Share on other sites More sharing options...
Rafael Posted September 14, 2015 Author Report Share Posted September 14, 2015 Thanks Sound like these.. Be carefule ¡¡¡have a lot of drops!!! UM200C-test.wav Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted September 14, 2015 Report Share Posted September 14, 2015 Did you try swapping antennas? Different frequencies? Different receiver? Make sure the battery contacts are firm? Quote Link to comment Share on other sites More sharing options...
Jonathan Michael Lau Posted September 14, 2015 Report Share Posted September 14, 2015 did water or actor sweat seep into the unit? i had a really sweaty summer and at one point had to blow dry the contacts from what was discovered, pooling sweat in the ta5. Quote Link to comment Share on other sites More sharing options...
TDP Posted September 14, 2015 Report Share Posted September 14, 2015 Squelch bypassed somehow? +1 on checking with something terminating the pack is a good first step. Bad antenna(e) / connection on the pack? What does it do when you remove the antenna and then plug it back on? Does it seat properly (does it wiggle / does the sound get worse when you move the antenna where it connects to the Tx)? I'm sure others will have more suggestions… Quote Link to comment Share on other sites More sharing options...
Rafael Posted September 14, 2015 Author Report Share Posted September 14, 2015 Hi Thanks to all well.. I did a lot of thing... and nothing change.. so these morning I open the Tx to look inside I found this... Thanks Sorry for the size of the picture Quote Link to comment Share on other sites More sharing options...
karlw Posted September 23, 2015 Report Share Posted September 23, 2015 Looks like corrosion on some of the pins. Could the transmitter have been subjected to moisture? Unfortunately, it probably does need to come in for service. Quote Link to comment Share on other sites More sharing options...
Rafael Posted September 24, 2015 Author Report Share Posted September 24, 2015 Thanks for replying I Don't know what happen and not have been exposed to moisture, normal use I'm looking for an used one to buy Thanks Quote Link to comment Share on other sites More sharing options...
ProSound Posted September 24, 2015 Report Share Posted September 24, 2015 Sweat will cause this too Quote Link to comment Share on other sites More sharing options...
mikewest Posted September 26, 2015 Report Share Posted September 26, 2015 Although a proper service by a certified agent is best, if you are desperate try using IsoPropyl alcohol on the board and gently clean with a soft tooth brush. Another thing to look for is dirt sitting in the 5 pin microphone connector - use a air can to remove it. mike Quote Link to comment Share on other sites More sharing options...
Rafael Posted September 27, 2015 Author Report Share Posted September 27, 2015 thanks everybody I´ll try these things the best Quote Link to comment Share on other sites More sharing options...
ShubiSnax Posted September 27, 2015 Report Share Posted September 27, 2015 Try to find someone local with an ultrasonic cleaner for electronics. That might be your best bet. Quote Link to comment Share on other sites More sharing options...
Rafael Posted September 30, 2015 Author Report Share Posted September 30, 2015 Ok.. Unfortunately no luck with isopropyl alcohol And no luck finding one to buy it from someone here So I'm thinking to buy one of these any suggestions? http://www.ebay.com/itm/LECTROSONICS-UM200C-UHF-TRANSMITTER-ONLY-BLOCK-27-3-/311449598274?hash=item4883d7b942 thanks for all I'm very happy with your help !! Quote Link to comment Share on other sites More sharing options...
