Focusrite SAFFIRE LE powered 12V AC or 12V DC??
Matthias Richter
I just posted on r.a.m.p.s. --- my conclusion is that it is DC. The only way to know for sure is to look at the external psu (wall wart) and see what the output spec is.
From literature online for the unit:
2.DC power adaptor input
This means that the interface can be powered by an external PSU
if required.The most common (larger, 6 pin) type of Firewire port
can supply power, so the use of an external power supply will not
normally be necessary. However, if the connected computer/laptop
only features the smaller 4-pin Firewire connector, which cannot
supply power, then the PSU must be connected.
-  Jeff Wexler
