AnuarYahya Posted November 8, 2015 Report Share Posted November 8, 2015 (edited) Has anybody conducted any tests comparing the performance of both the TRXLA2 and the TRXLT2? Am I right to assume that the TRXLA2 would outperform the TRXLT2 just because it has a higher power output? Just curious. Edited November 8, 2015 by AnuarYahya Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 8, 2015 Report Share Posted November 8, 2015 Why are trx900lt2 not 125mW? it should be available as an option. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted November 8, 2015 Report Share Posted November 8, 2015 Other than physical size there are only two other differences between the LT and LA. One is the LT has one battery vs two in the LA. The other thing is the LA has user selectable output power levels (25, 50 and 125mW) while the LA is set at 50. The LT only does 50mW because anything higher puts too much of a demand on the single AA and the run time is quite short. Will it "outperform" because it has higher output power? Not necessaraly. 125mW in some situations may be better and in some worse but it's nice having the option. I personally usually set the power level on my LA's to 50mW perhaps 95% of the time. But there are times I need and use 125. Quote Link to comment Share on other sites More sharing options...
efksound Posted November 8, 2015 Report Share Posted November 8, 2015 (edited) Has anyone tried to convert a TRXLA to LT? In some situations the size of the LT would be usefulSo besides getting an empty LT case from Zaxcom would there be something else to change?Maybe a mod to allow the TX to work with only 1.5v instead of 3v? Edited November 9, 2015 by efksound Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 8, 2015 Report Share Posted November 8, 2015 (edited) My trx900lts have 125mW but I have not noticed any difference in performance. Maybe there are not 125mW just have the menu. Edited November 8, 2015 by RadoStefanov Quote Link to comment Share on other sites More sharing options...
AnuarYahya Posted November 9, 2015 Author Report Share Posted November 9, 2015 Other than physical size there are only two other differences between the LT and LA. One is the LT has one battery vs two in the LA. The other thing is the LA has user selectable output power levels (25, 50 and 125mW) while the LA is set at 50. The LT only does 50mW because anything higher puts too much of a demand on the single AA and the run time is quite short. Will it "outperform" because it has higher output power? Not necessaraly. 125mW in some situations may be better and in some worse but it's nice having the option. I personally usually set the power level on my LA's to 50mW perhaps 95% of the time. But there are times I need and use 125. Great reply, thank you! Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted November 9, 2015 Report Share Posted November 9, 2015 FYI the difference in size between the LT and the LA is about the width of a AA battery making the LA just slightly taller. All other dimensions are the same. Quote Link to comment Share on other sites More sharing options...
