The Ampex 300 Audio Recorder, looks like a 3 Track setup. Left _ Center_Right.
Transport is separate from the Electronics
 This machine predates me though Eric Toline probably worked with it.
Those are not standard 300 electronics, they are from the 350/351 recorders. Ampex 300 electronics were housed in the bottom of the unit and were accessed by opening the front panel. The VU meter was mounted in the sloping panel above the deck. The heat from the tubes inside was enough to heat your lunch.
