Weird noise on sennheiser g3
cinetj
Possibly some kind of external switching noise sneaking in, the three 'hits' are spaced exactly at 6.7 sec.
Do you mean "when the transmitter is off? If so, you could try a higher squelch setting, the EK100 receiver's default is minimum.. (if that's the model you have). For the EK100 and most other unbalanced connections, XLR pins 1 & 3 are tied together.
