josephboyle Posted June 6, 2016 Report Posted June 6, 2016 Hello everyone, First time posting here. I recently purchased a Sanken Cos-11d (Normal Sensitivity) and the connector seems very shoddy to me, for what is supposed to be a very high quality mic. I checked with a friend of mine and he verified that the connector on his is different (we are both using the same 1/8" connection for a Sennheiser G3 system). I purchased it through B&H, so I assume that it is genuine. The connector says Hicon on the outside and it is made of plastic. Often times, when I attach or removed it from the transmitter, the Hicon plastic part comes unscrewed from the tip and exposes the solder points, which also seem pretty weak. Can anyone verify if this is the genuine connector or if theirs came with this as well? I have attached photos. Also, on a related note, I have heard a bit of crackling sound with this mic, even when it isn't close to peaking (around -12dB). Originally, I thought it was because I had the signal too hot at my transmitter or receiver on the G3 system. But, then I attached it directly to a JuicedLink Little DARling, which only has a simple gain setting, and it is still crackling. It only occurs with a voice though, and isn't cable noise. Any idea what could be causing this? (I apologize if my explanation isn't using the best terminology - I do audio out of necessity, but am not a dedicated sound mixer). Thanks! -Joseph
Jack Norflus Posted June 6, 2016 Report Posted June 6, 2016 Sanken doesn't terminate the microphones - that is something the dealer does. I'm assuming that B&H uses shitty connectors. That is why you should buy from a professional audio dealer.
josephboyle Posted June 6, 2016 Author Report Posted June 6, 2016 Ahh, I see. Thanks for the info. Is it possible or common to get it re-terminated? If so, do you know how much that would cost generally, and do you have a suggestion for a specific one? I'm in Orlando, FL, but could ship somewhere else.
Glen Deakin Posted June 6, 2016 Report Posted June 6, 2016 Of course you can get it we terminated as for cost it depends on good connector which you will want to get either a genuine Sennheiser ,switchcraft or an audio LTD connector plus labor
VASI Posted June 6, 2016 Report Posted June 6, 2016 Worst connector. We had problems recently with them. Change connectors.
Eric Toline Posted June 6, 2016 Report Posted June 6, 2016 The wiring is wrong for a COS11 into a Sennheiser transmitter. I can help you with a new connector wired properly for that system. Contact me at 954-415-8806.
al mcguire Posted June 7, 2016 Report Posted June 7, 2016 Those who know let their Uncle Eric worry about it.
josephboyle Posted June 7, 2016 Author Report Posted June 7, 2016 Thanks for the information everyone! I will be giving Eric a call!
Lancashire soundie Posted June 7, 2016 Report Posted June 7, 2016 Not even any heatshrink or a cable boot, that's ropey as hell. I'd also be complaining to B&H tbh. Not good enough.
josephboyle Posted June 24, 2016 Author Report Posted June 24, 2016 Just as a quick update, Eric down in Ft. Lauderdale rewired the mic and it sounds great. He's the man!
josephboyle Posted July 1, 2016 Author Report Posted July 1, 2016 Hey Everyone, Here is a clip of the issue that I was having with this mic. This was before it was rewired, but I'm wondering if anyone hears the issue I am hearing and can give me an idea of what is going on. His voice sounds harsh when he says "Tired" (specifically on the 'R' sound) and "Jet-lagged" (specifically on the 'G' sound). I don't think it is clipping (please correct me if I'm wrong). Could this be an issue with how his voice interacts with the mic or maybe an issue that can be remedied with proper EQ? https://www.dropbox.com/s/h4gzw5ky320k80f/audio-test.mp4?dl=0 This is the setup, as far as I can remember: Sanken COS-11D (wired like the photos above, taped underneath his shirt) into Sennheiser G3 wireless (-18dB on the body transmitter, -12dB on the receiver), being fed into a Tascam DR-60D ii (set on low gain, potentiometer @~75%). This is the raw audio with no extra processing or gain applied. Thanks for having a look!
Eric Toline Posted July 1, 2016 Report Posted July 1, 2016 Thanks for the nice words Joe, the wiring problem with that mic was that it was also sending a signal to the line input side of the tx. I rewired it so no signal went to the line side and the required bias current went to the mic input.
josephboyle Posted July 8, 2016 Author Report Posted July 8, 2016 Ahh, that makes sense. Thanks for the explanation and the excellent work Eric.
Create an account
Register a new accountSign in
Sign In Now
