Philip Perkins Posted June 8, 2016 Report Share Posted June 8, 2016 I saw this box on the PinkNoise site, a very clever looking add-on for the 633 to give it 3 more mic pres. I wonder if they've thought of a similar box for 664-88? Quote Link to comment Share on other sites More sharing options...
jozzafunk Posted June 8, 2016 Report Share Posted June 8, 2016 Filmteknic or Kortwich have had a 3 pre for the 633 for a while, thought they may have made a bigger version but can't find annything on the site at moment Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted June 8, 2016 Report Share Posted June 8, 2016 Very cool. Would have been nice if it had input 4 5 6 written instead of 1 2 3 since it's being designed to pair with the 633. Quote Link to comment Share on other sites More sharing options...
daniel Posted June 9, 2016 Report Share Posted June 9, 2016 I don't get it. What's the point of having faders on this box? Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 9, 2016 Author Report Share Posted June 9, 2016 Easier to mix on for fat fingers? Were you thinking they should have only trims? Quote Link to comment Share on other sites More sharing options...
Mobilemike Posted June 9, 2016 Report Share Posted June 9, 2016 1 hour ago, Philip Perkins said: Easier to mix on for fat fingers? Were you thinking they should have only trims? It does seem like having faders on this box might make gain-staging on the 633 a little tricky, as you would still be going through those faders on ch. 4-6 as well. I'd love to hear sound quality reports from anyone who has used this box though! Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted June 9, 2016 Report Share Posted June 9, 2016 16 hours ago, jozzafunk said: Filmteknic or Kortwich have had a 3 pre for the 633 for a while, thought they may have made a bigger version but can't find annything on the site at moment They also do a four five and six way units, but this looks like a cracking bit of kit. My only surprise is the external power socket. It's a standard DC plug whilst the DC in and out on the 633 is 4 pin. hirose. Quote Link to comment Share on other sites More sharing options...
chrismedr Posted June 9, 2016 Report Share Posted June 9, 2016 12 hours ago, Malcolm Davies Amps CAS said: My only surprise is the external power socket. It's a standard DC plug whilst the DC in and out on the 633 is 4 pin. hirose. seem to have changed to 4pin hirose: specs are quite nice too: SD633 Add-On Gain range 20 … 78 dB Max input signal -2 dBu Max output signal +24 dBu @ 10K ohms (bal) Frequency response 20 ... 40 kHz +0 / -0.8 dB THD+N 0.001% @ -14 dBu, 1 kHz, 38 dB gain 0.04% @ -54 dBu, 1 kHz, 78 dB gain Equiv. input noise -127 dBu, A-weighted @ 78 dB gain Phantom voltage 48 V +-2 V, max 15 mA Power supply 6 x AA alkaline or NiMH batteries for 6 - 10 hours continuous use Ext. DC 6 - 18 V (HIROSE HR10 4pin) Size WxHxD 203 x 40 x 125 mm Weight 980 grams http://www.pinknoise-systems.co.uk/PN-SD633-3CH-EXP.html 460GBP plus tax Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted June 9, 2016 Report Share Posted June 9, 2016 All 3 outputs on a single TA7? Ugh.. Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted June 9, 2016 Report Share Posted June 9, 2016 Ii even know TA7 existed. Thought they maxed out at 5. I'm curious what brand of ta7 that's used in picture of the output cable on their site. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 10, 2016 Author Report Share Posted June 10, 2016 I looked at Kortwich's versions of these (1/2/3/4/6 channel). They look good but their site is pretty light on info about them. Anyone used one? It seems like the vis the 6xx design, the controls on these boxes would be mic trim only, you'd still be mixing on the SD box. Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted June 10, 2016 Report Share Posted June 10, 2016 5 hours ago, Philip Perkins said: I looked at Kortwich's versions of these (1/2/3/4/6 channel). They look good but their site is pretty light on info about them. Anyone used one? It seems like the vis the 6xx design, the controls on these boxes would be mic trim only, you'd still be mixing on the SD box. Phillip. When I bought a 633 I bought the 3 way and found it very quiet and it did exactly what it was supposed to. For another project I bought a mini Solice so I bought the six way which compliments the Solice beautifully. When I saw a photo of the Pink Noise one, I might have been having a senior moment but it certainly didn't have the Hirose in and out just a dc non-locking socket I thought a the time "pity it doesn't have the Hirose to match the 633. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 10, 2016 Author Report Share Posted June 10, 2016 It's cool to think of having a compact way to add 6 more pres to my 664, but to make a mix that avoided essentially mixing on the input trims (so the isos would be going up and down w/ the mix) I guess I'd still need the CL6 too (and set-and-forget the 664 trims for 7-12). But still a pretty compact rig. Good to hear that the pres are nice sounding, boffo idea combining the Kortwich 6x version with mini Solice--nice little rig that would be. Quote Link to comment Share on other sites More sharing options...
