Power adapter for both sound devices 744 and mix pre-d
knod
On 744t, 1&2 are combined and 2&3 are combined if you want the charger (or cable) to charge the on board battery. Otherwise, you only want to build the Hirose with 1 & 4.
I believe on all other machines it doesn't matter, as pins 2&3 don't go anywhere inside the machine.
I have spoken to SD in the past, and seem to recall the power supplies combine 1&2 and 3&4 in case they are used with 744T, but I can't be sure.
