Wandering Ear Posted September 6, 2016 Author Report Share Posted September 6, 2016 48 minutes ago, mulluysavage said: Does it run in Linux? Sent from my XT1080 using Tapatalk It won't have a GUI on Linux, but you could download the source code and the necessary utilities, then run the shell script. A little more setup is required, but I don't see why it wouldn't work. PM me if you want to try to set it up and I can help. Quote Link to comment Share on other sites More sharing options...
mulluysavage Posted September 6, 2016 Report Share Posted September 6, 2016 Thanks, I might take you up on that, Do you know if there is already a command - line tool that does this already? Sent from my XT1080 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted September 6, 2016 Author Report Share Posted September 6, 2016 You can use the source code from this app as a command line utility to do the conversion, you will just need to make sure the dependancies are installed, and possibly set the install locations. Quote Link to comment Share on other sites More sharing options...
