JWL Posted July 11, 2016 Report Share Posted July 11, 2016 Hi there, Have just purchased 6 TRXLA3's and my sound assist cannot pickup confidence monitoring on his/her erx reciever. Its strange, The Zaxnet frequencies are the same and the ERX's light goes green to show a signal is being picked up but alas nothing can be heard (record beeps or audio). Via UHF the QRX235's I have in my cart can pickup the TRXLA3's uhf signal fine, And The ERX's can pick up the QRX's IFB transmition (on a different 2.4 ghz Frequency) fine as well. But the signal from the TRXLA3's zaxnet output direct to the ERX's (1st gen and latest gen) cannot be heard. Which is challenging as the Sound assist needs to hear the beeps to confirm that the packs are rolling record. The firmware on the ERX's are up to date. Does anybody have a fix? Just to confirm the packs are : TRXLA3's (mono). THe IFB's are a combo of ERX3TCD and ERX2TCD both tried. The Cart recievers are new QRX235's with the IFB option. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted July 11, 2016 Report Share Posted July 11, 2016 Group and/or encryption settings? Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted July 11, 2016 Report Share Posted July 11, 2016 What Zaxnet mode do you have set in the TRX menu? Also, do you have the ERX set to voting to switch between the QRX signal, and the TRX signal? If so the weak signal from the TRX may not be strong enough and the ERX will constantly switch back and forth. Try manually choosing the frequency. Quote Link to comment Share on other sites More sharing options...
JWL Posted July 12, 2016 Author Report Share Posted July 12, 2016 zaxnet mode is TX (RX PULSE MODE) Quote Link to comment Share on other sites More sharing options...
bralleput Posted July 12, 2016 Report Share Posted July 12, 2016 sorry JWL this is a test.. Jeff it worked! ( sorry again JWL..!) Quote Link to comment Share on other sites More sharing options...
JWL Posted July 12, 2016 Author Report Share Posted July 12, 2016 No Worries!! Software update from Zaxcom fixed my IFB problem fyi. v70 Quote Link to comment Share on other sites More sharing options...
