pierrecarlier Posted November 12, 2016 Report Share Posted November 12, 2016 Hello everybody Hello everyone I would like to know the maximum distance of the microphone from the mouth of an actor to have a correct result ? 50 cm ? 1 meter ? With the mkh50 we can be high but i dont know with the dpa 4017c... Can you answer me ? Thank you very much Quote Link to comment Share on other sites More sharing options...
Bash Posted November 12, 2016 Report Share Posted November 12, 2016 The answer depends entirely on the acoustics of the room you use the microphone in. The words to search for are 'Critical Distance'. The point of critical distance in a room is the point where the level of the direct sound (from a source) and the reverberant sound are equal. This point, in any room, may well be altered by the pickup charcteristics of the microphone you are using/testing. In practice, your ears will usually tell you what distance between actor and microphone, in a particular room, 'sounds right'. Closer than this point sounds 'nicer', and further away than this point feels 'a bit too far away'. Use your ears Luke, it's like The Force. Kindest, Simon B Quote Link to comment Share on other sites More sharing options...
pierrecarlier Posted November 12, 2016 Author Report Share Posted November 12, 2016 With the mkh60 you can be very high in ext, room or whatever... With my km185 in interior i cant have a nice sound if i m too high.The sound seems too far.. With a mkh50 i can be higher than km185 for a very good résult I dont know the DPA.... Just tell me if this microphone 4017c can be high or not to take à good and nice voice. I need a nice micro for interior because the mkh60 take reverb by his back side. Thank you Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted November 12, 2016 Report Share Posted November 12, 2016 I haven't used the DPA but many people say the 4017 sounds similar to Schoeps' CMIT. That means, they work well outside and also inside as long as the ceilings aren't too low and there aren't too many reflections. MKH50 for interiors is great, if you already have a 60 for exteriors that's what I'd recommend. Quote Link to comment Share on other sites More sharing options...
pierrecarlier Posted November 12, 2016 Author Report Share Posted November 12, 2016 Thank Christian I know very Well the cmit and the mkh50. I would like to try the 4017c because i think it Will be à marvelous tool. Quote Link to comment Share on other sites More sharing options...
JonG Posted November 13, 2016 Report Share Posted November 13, 2016 The answer is that it depends on many things. Try it and see for yourself. They're all great mics. If you read the spec sheets on them, that should give you an idea of what their capabilities are relative to each other. Quote Link to comment Share on other sites More sharing options...
pierrecarlier Posted November 13, 2016 Author Report Share Posted November 13, 2016 Thank you for answer. I ve to test it ! Quote Link to comment Share on other sites More sharing options...
julian Posted November 15, 2016 Report Share Posted November 15, 2016 I have both 4017c and MKH50. Did a series all indoors and we tried the 4017 a few times on wide shots and found that it often picked up more reflections than the mkh50. Which makes sense since it's a shotgun. For closer framing it sounds amazing and it's a perfect interview mic for talking heads indoors and outdoors. Outdoors I was surprised at how much reach the 4017 has. Quote Link to comment Share on other sites More sharing options...
Mack Posted November 15, 2016 Report Share Posted November 15, 2016 I have had good luck using the 4017 inside. This is a versatile mic. I agree with Julian above. Quote Link to comment Share on other sites More sharing options...
