Adapting TA-5F Audiotechnica AT898 to Sennheiser G2/G3
Cedric Akins
I've made adapters for many mics to be used with Sennheiser G series wireless. The 3.5 mm side is always the same, positive to the tip & ground to the sleeve. As an example for TA5 wired for Lectro you'll need a male TA5 wired as follows. Jump pins 2 & 4 with the ground to pin 1 and positive to pin 3.
I have had the shop @ LSC make me various lav adapters (Lectro connectored Countryman>Shure TX, Shure connectored DPA to Lectro TX) and they worked fine, not very expensive, very fast turnaround.  I had mine made kind of short (6"), you might consider having the adapter cable be longer so you can stow the "join" better and not have it dangling.
