mikeodmark Posted January 3, 2017 Report Share Posted January 3, 2017 Has anyone had luck modifying the new version of the Rode Blimp (with the rycote lyres) to fit the Rode NT4? I'm trying to find a windshield solution that won't cost more than the mic :| Based on the pictures, it seems like it should be easy to simply unscrew the current lyres and replace them with the 30mm upgrade sold by Rycote (https://www.bhphotovideo.com/c/product/629616-REG/Rycote_042218_042218_30mm_Lyre_Upgrade.html/mode/edu) I'd love to hear if anyone has any other ideas or knows if my solution will work or not. Thanks! mike Quote Link to comment Share on other sites More sharing options...
jhharvest Posted January 3, 2017 Report Share Posted January 3, 2017 I don't know if it's relevant to you but I have one older Rode blimp that I replaced the O-ring suspension with Rycote lyres. I can't remember it being particularly difficult, although I did have to put in some spacers for whatever reason. Quote Link to comment Share on other sites More sharing options...
mikeodmark Posted January 3, 2017 Author Report Share Posted January 3, 2017 1 hour ago, jhharvest said: I don't know if it's relevant to you but I have one older Rode blimp that I replaced the O-ring suspension with Rycote lyres. I can't remember it being particularly difficult, although I did have to put in some spacers for whatever reason. Thanks for the response. I've found that the older blimp is impossible to find since it's been discontinued, that's why I'm asking specifically about the new version. Quote Link to comment Share on other sites More sharing options...
allistair Posted January 5, 2017 Report Share Posted January 5, 2017 I didn't do it specifically for the NT4, but when I briefly owned the Rode Blimp 2 I was able to just swap the lyres out with replacement Rycote ones pretty easily. Quote Link to comment Share on other sites More sharing options...
mikeodmark Posted January 6, 2017 Author Report Share Posted January 6, 2017 thanks, allistair! Good to know. Quote Link to comment Share on other sites More sharing options...
AnthonyRamirez Posted June 5, 2017 Report Share Posted June 5, 2017 Sorry to bring up an old post. But I am running into the same problem putting a Rode NT4 into my Rode Blimp2. Was wondering if you found a solution? Quote Link to comment Share on other sites More sharing options...
Fabio Duarte Posted December 23, 2018 Report Share Posted December 23, 2018 I'm interested in details about that swap. Correct me if i'm wrong, but the blimp has a groove where the lyres attach, and the invision lyres are screwed directly on the shockmount base, right? I need stiffer lyres for MKH416 P48. With the original ones, it wobbles around A LOT. Thanks! Quote Link to comment Share on other sites More sharing options...
Humhed Posted January 3 Report Share Posted January 3 Old thread, but FYI- no modification is necessary for an NT4/4+ to fit in the Rode Blimp. It accepts mics up to 22mm in diameter. The NT4 is 22mm in diameter. Dunno why the OP thinks 30mm lyres are necessary... Quote Link to comment Share on other sites More sharing options...
borjam Posted January 4 Report Share Posted January 4 The standard lyres included with the Blimp 2 are too soft. I had to replace mine in order to support a mile long NTG8 because of the weight. In my case I got "82 shore" lyres, which are the stiffest as far as I know. Due to the way lyres are fitted to the boom I had to add a couple of plastic spacers in order to place the microphone at the right position. Quote Link to comment Share on other sites More sharing options...
Throwback Posted January 4 Report Share Posted January 4 17 hours ago, Humhed said: Old thread, but FYI- no modification is necessary for an NT4/4+ to fit in the Rode Blimp. It accepts mics up to 22mm in diameter. The NT4 is 22mm in diameter. Dunno why the OP thinks 30mm lyres are necessary... The Rode NT4 is 33mm diameter: it is a chunky-bodied stereo mic. Given your ref to the 'NT4/4+', it looks like you have confused this with the NTG4 (and NTG4+) shotgun mic. Cheers, Roland Quote Link to comment Share on other sites More sharing options...
