Paul5000 Posted March 12, 2017 Report Share Posted March 12, 2017 I came across this item and I can't find out any information about it. The barrel slides open and allows you to put in (6) 1.5 volt button batteries in. If it is a inline mic power supply, will it take the place of other power supplies. Any information would be greatly appreciated. I was unable to upload any pictures Quote Link to comment Share on other sites More sharing options...
David Waelder Posted March 12, 2017 Report Share Posted March 12, 2017 Can't say for sure without more information, especially pictures, but it sounds like a power supply for T-power that Sennheiser offered for their "04" series (MKH 404, MKH 805, etc.) microphones. With that battery supply in-line, one could plug the microphone into a regular 200-Ohm input. It worked fine but, as I recall, didn't run the microphone for more than a day, necessitating an expensive battery reload each work day. I think it would probably work (if you could afford to feed it) with "05" and "15" series Sennheisers as well and maybe also Schoeps. David Quote Link to comment Share on other sites More sharing options...
JonG Posted March 12, 2017 Report Share Posted March 12, 2017 Could be for T power or a Sennheiser only power used briefly. I'm guessing it's the ladder. Quote Link to comment Share on other sites More sharing options...
Paul5000 Posted March 12, 2017 Author Report Share Posted March 12, 2017 I downsized the images and they uploaded. Quote Link to comment Share on other sites More sharing options...
David Waelder Posted March 12, 2017 Report Share Posted March 12, 2017 As I thought, a Sennheiser power supply. With the Tuchel connection, one would usually mount the power supply directly to the microphone, making a single, rigid cylinder, albeit about 3 inches longer. I believe the device could also be used anywhere in line between the microphone and regular preamp. David Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted March 12, 2017 Report Share Posted March 12, 2017 David's got it right --- I was looking for images myself before posting the answer and your images showed up and David confirmed the item. It was an accessory for the Sennheiser line of microphones and it was essentially a barrel with Tuchel to Tuchel connectors. I used this item a few times and thankfully the batteries lasted quite a long time because it wasn't too much fun loading all those button batteries, getting the polarity correct, etc. Quote Link to comment Share on other sites More sharing options...
David Waelder Posted March 12, 2017 Report Share Posted March 12, 2017 Jeff Wexler: ...thankfully the batteries lasted quite a long time because it wasn't too much fun loading all those button batteries, getting the polarity correct, etc. Thanks for the confirmation, Jeff. My recollection was that the batteries didn't have a long service life but I only used the device once or twice more than forty years ago. My memory might easily have been distorted by the nuisance aspect of buying and aligning all those cells. David Quote Link to comment Share on other sites More sharing options...
Paul5000 Posted March 12, 2017 Author Report Share Posted March 12, 2017 Thanks David and Jeff, I appreciate the information. I'll try it with my MKH404. Quote Link to comment Share on other sites More sharing options...
