Syoung Posted June 29, 2017 Report Share Posted June 29, 2017 The company I'm currently working with is considering buying a Telex BTR-800 system which operates between 470-600Mhz. It's a fairly small sound stage and I'm wondering if anyone has had any significant interference problems with these systems using Blocks 19-21 for their wireless. TIA, Sam. Quote Link to comment Share on other sites More sharing options...
sonicboomaudio Posted June 29, 2017 Report Share Posted June 29, 2017 The BTR-800 has a scan function that will choose the range of frequencies that are most clear. You should power up any mics that will be used and then do the scan. Even if there is a conflict, you can change/edit the Tx or Rx freqs to avoid the conflict. Quote Link to comment Share on other sites More sharing options...
Syoung Posted June 29, 2017 Author Report Share Posted June 29, 2017 Right. I guess I'm more concerned with the frequency deviation muddying up the air but it looks pretty tight (40kHz) Probably thinking a little too much into it. Thanks! Quote Link to comment Share on other sites More sharing options...
