Joe Riggs Posted July 28, 2017 Report Share Posted July 28, 2017 I'm trying to add 1 mono file to a 8 track poly file, when I bring them into wave agent and press combine it says the process is complete but nothing happens. Can someone let me know the proper procedure to accomplish this? I should add this lone mono file is from a separate recorder, that's started a little later than the first recorder, so is it even possible to combine it in Wave Agent? Do I have to take it into a NLE or DAW, sync them, then export a 9 track poly? Thanks Quote Link to comment Share on other sites More sharing options...
nickreich Posted July 28, 2017 Report Share Posted July 28, 2017 combining different start times isn't possible in Wave Agent. Other Poly mergers can do it but they'd align the files from the front edges which would be out of sync - so yes, you'd need to spot them to timecode (or waveform match them) in a DAW and re-export. Quote Link to comment Share on other sites More sharing options...
Mobilemike Posted July 28, 2017 Report Share Posted July 28, 2017 I believe that PolyWAV files by definition need to have all channels be the same length down to the sample, so may be best to combine in a DAW and consolidate and export like @nickreich suggested. -Mike Quote Link to comment Share on other sites More sharing options...
Joe Riggs Posted July 28, 2017 Author Report Share Posted July 28, 2017 What are some other poly merger applications? Quote Link to comment Share on other sites More sharing options...
nickreich Posted July 29, 2017 Report Share Posted July 29, 2017 There's a freeware Mac one called SoundFilesMerger which works well, but only for merging - not with all the timecode and metadata functions we need for Film work. In the WIN world, BWF Widget from Courtney Goodin comes with a merger/splitter utility. Quote Link to comment Share on other sites More sharing options...
