Zack Posted December 2, 2017 Report Share Posted December 2, 2017 Nearly same gain settings here Quote Link to comment Share on other sites More sharing options...
LarryF Posted December 2, 2017 Report Share Posted December 2, 2017 1 hour ago, Shawnkirkby said: Has anyone noticed a change in the gain on the SMWB? I have had to set the gain almost double what it is on my SMQV to match the output. Sent from my SM-G930W8 using Tapatalk Input and audio sections should be identical between the SMQV and SMWB. Something is not right. Are your comparisons done using the same mic or cable? Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
Shawnkirkby Posted December 2, 2017 Report Share Posted December 2, 2017 Input and audio sections should be identical between the SMQV and SMWB. Something is not right. Are your comparisons done using the same mic or cable? Best Regards, Larry Fisher Everything is the same, tried different lavs, same recievers. Sent from my SM-G930W8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
LarryF Posted December 2, 2017 Report Share Posted December 2, 2017 6 minutes ago, Shawnkirkby said: Everything is the same, tried different lavs, same recievers. Sounds like something has broken. Specific gain values is one of many things tested on each audio board. How old is the unit? LEF Quote Link to comment Share on other sites More sharing options...
Shawnkirkby Posted December 2, 2017 Report Share Posted December 2, 2017 Sounds like something has broken. Specific gain values is one of many things tested on each audio board. How old is the unit? LEF Just bought them today. Sent from my SM-G930W8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
LarryF Posted December 2, 2017 Report Share Posted December 2, 2017 4 hours ago, Shawnkirkby said: Just bought them today. Ouch. You should be able to get an exchange started through dealer plus Lectro. Only potential hangup is the backlog, though you would be absolute top priority at the factory. LEF Quote Link to comment Share on other sites More sharing options...
Patrick Tresch Posted December 16, 2017 Report Share Posted December 16, 2017 Appart from the 44.1kHz vs 48kHz, is the recorder in the SMWB the same as in the PDR version? Thanks Pat Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted December 16, 2017 Report Share Posted December 16, 2017 3 hours ago, Patrick Tresch said: Appart from the 44.1kHz vs 48kHz, is the recorder in the SMWB the same as in the PDR version? Thanks Pat Yes it is. Quote Link to comment Share on other sites More sharing options...
