benr Posted September 23, 2017 Report Share Posted September 23, 2017 Looking to make some custom cables to use with my new Sound Devices MixPre-6 and would like to use some low profile XLR connectors. There seems to be two on the market but the pricing difference between the two is substantial. So I thought I'd ask around here and see if anyone out there has experience working with both and can comment on the differences. There is the Cable Techniques option, which retails for about $15/connector: LINK And the Remote Audio option, which retails for about $25/connector: LINK Both have options for color coded caps (though the Remote Audio colored caps are more expensive) and both require a thinner cable to be used for which I was planning to go with Mogami W2697 miniature microphone cable (LINK). Anyone tried both of these and can comment on whether or not the Remote Audio connectors are worth the higher cost? I am planning to purchase 4-8 of these in male and female configuration so if the Cable Techniques are the same quality or better it would save me quite a bit of coin to go with them. Quote Link to comment Share on other sites More sharing options...
Carlos Maeda Posted September 24, 2017 Report Share Posted September 24, 2017 I've only soldered the Remote Audio option, but have seen and held the Cable Techniques one as well. The RA design is physically smaller than a Neutrik straight or angled connector, but seemed to weigh slightly heavier. I used these as a replacement to the horrible K-Tek ones that come with their Klassic poles. The RA option uses a metal cap that only offers 4 possible angles for cable routing (45, 135, 225, and 315). The angles didn't bother me since I was using this at the end of a pole, but could see how that could pose a problem in a bag. I was surprised at how small and light the CT design was when I first held one. Really like how variable the cable angle can be adjusted to, but is a molded plastic so it's definitely not as strong as the RA's all-metal cap. Considering you plan on using these in a bag, I'd save some money and go with the CT option. Quote Link to comment Share on other sites More sharing options...
tourtelot Posted September 24, 2017 Report Share Posted September 24, 2017 Just used the Cable Techniques lo-profi XLRs on some SD cables for a friend. These are the easiest XLR connectors to solder and get "right" of any I have ever used! Well-built as well. I have zero complaints about them. Curious about the lo-profi TA connectors now. D. Quote Link to comment Share on other sites More sharing options...
benr Posted December 11, 2017 Author Report Share Posted December 11, 2017 Awesome. Thanks guys. Think Ill give the Cable Techniques ones a try. Quote Link to comment Share on other sites More sharing options...
Dave Pullmer Posted March 2, 2019 Report Share Posted March 2, 2019 I have a question regarding the RA lo profile connectors. Making a jumper cable from mic to plug on, and I cant figure out how to lock the removable black remote audio cap to the actual neutrik connector part. Right now its fully removable, but when in operation how do you lock it down? Im expecting an obvious answer but I cant figure it out this morning ! Quote Link to comment Share on other sites More sharing options...
