MKH40 high pitch noise
Levente Udud
Hello all!
My recently purchased used MKH 40 just did the strangest thing last week and again today, this modulating high pitch noise appeared depending on mic position and angle.
Today the problem went away after a couple of minutes, but it may come back anytime.
Anyone experienced simiar issues with a MKH mic?
Thank you for your input
MKH40_noise.wav
Based on the quoted phrase alone this made me think the mic is simply picking up something in the environment. If it was a problem with the microphone itself I would think the noise would be present no matter what the mic position and angle is.
-Mike
The only time I've had something like an intermittent problem with a senny (depending on mic angle/position) the sound was very different and it was because something had come loose inside - it had been a badly treated rental.
IIRC sennheiser charge c. 200 for servicing mics and this includes everything except a new capsule. When I've bought second hand sennheisers I have tried to factor this in when deciding what I'll pay. If you need the piece of mind to know you can take this mic on job - send it for servicing.
Thank you all for your input, I have a quite good relationship with my local Sennheiser Service shop and they are in walking distance, so I'm definitelygoing to head there.
MobileMike, RadoStefanov: Yes, I troubleshooted, and it's definetly the mic, and I think it's an internal issue, I couldn't recreate the problem on the spot and since either.
