wireless receiver antenna
newzhack
1 hour ago, Constantin said:
You want to cut the 1031? This antenna is not meant to be cut. It’s a wideband antenna and cover 450-950 MHz.
They work ok. I used them for my iem system. As they are omni antennas I thought they covered an overall larger area.
two questions. I had a boom op that was helping me pack and took all the antennas off my transmitters and mixed them up. I had not color coded them. I have two in the 500 range and two in the 600's. I thought if I had a chart I could get them back on the right transmitters. I wanted to check the receivers too.
20 hours ago, Eric Toline said:
Really easy, the 500 range antennas are longer than the 600 range. The two shortest are the 600.
thanks.
Now I am trying to find Sennheiser 55640 connector to BNC to use these. I have found a supplier in the UK but nothing in the US.
