Ursa Pro Mini AES not working
withintheflux
  • 7 months later...
Blackmagic Ursa mini pro 4.6 Aes inputs work just fine with Zaxcom Nomad. The only Zaxcom thing is, Nomad AES outputs are inverted in polarity when compared to analog outputs and card tracks. Howard Stark said it's a hardware limitation.
You can invert any signal(individually) that gets routed to Output busses, except automix - then everything that goes thru out buses gets inverted, naturally so, if you're recording your outputs as a mix track, that gets inverted too.
You cannot invert polarity of the output sum at the card track matrix.
