Dalton Patterson Posted April 27, 2018 Report Share Posted April 27, 2018 More Schoeps Cleaning... This is an upgraded Duran amplifier. Critical listenting test-PASS Quote Link to comment Share on other sites More sharing options...
pverrando Posted June 1, 2018 Report Share Posted June 1, 2018 The interior condition of that CMC is pretty crazy. The XLR leads, RF bypass caps, both electrolytics replaced with japanese units, also probably the FET, and 1 gig resistor have all been replaced. The circular connector has been removed and replaced with nuts and bolts. The whole amplifier structure seems to have been stripped and replaced, including the transistors, which should be closely matched and have a mininum current gain of 450, typically 500, and they should have an RF bead on the base lead. -Pete Verrando Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 1, 2018 Report Share Posted June 1, 2018 That is one scary looking CMC. Was that a repair job or someone's attempt at a hot-rod? That thing is so Frankesteined that I don't think you can really call it a Schoeps any more... Do you know the history of that unit? Was it water-damaged or? Quote Link to comment Share on other sites More sharing options...
tourtelot Posted June 1, 2018 Report Share Posted June 1, 2018 No need to take a peek at the inside of Pete's re-works. They are spotless. :):) Oh, and Dalton Great idea for near-field mic testing. Would have never thought of that. D. PS. If anyone has any CMC4s for $250 each, I'll buy them all. Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted June 2, 2018 Author Report Share Posted June 2, 2018 So much history. I cannot say for sure this was the exact mic used, I won't speculate. It is the real deal. No hotrod. @pverrando I have a 12T Power Schoeps with your name on it as soon as I get some extra cash. I've only heard positive things. Quote Link to comment Share on other sites More sharing options...
