SD 633 X3/X4 question
cmassey
Yep, therein lies the rub. as i scroll thru the tracks on the X3/X4 routing page, I don't get a highlighted green for prefade...just no highlight for off or solid blue for post-fade.  I can't seem to figure it out....
Quote
Quote
You should be able to set the ISO tracks to prefade by preselecting the prefade option in the bottom line of the output / x3x4 / menu.
You can not put L R or x1x2 to prefade, but that is in the nature of things as they are postfade.
'Input to ISO Routing' - Are your ISOs are set to 'Postfade'?
I just checked on my 633, whatever option is selected in 'Input to ISO Routing' has no bearing on the X3/4 routing page.
My X3/4 routing page allows:
Postfade (only) from L/R and X1/2.
Prefade (only) from ISO tracks.
Which kind of makes sense.
