MartinTheMixer Posted August 16, 2018 Report Share Posted August 16, 2018 It works, it works. It took me a little while to figure it out (I have never operated a Deva). But it works. It's right up there with phasers, actually it's more like a transporter room because now, you can beam up audio. Quote Link to comment Share on other sites More sharing options...
Mobilemike Posted August 16, 2018 Report Share Posted August 16, 2018 Dang, that is really cool! -Mike Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted August 17, 2018 Author Report Share Posted August 17, 2018 Mike, Yes, but, I'm not sure how I would find just the section that I want to re-record. Lots of questions on this. In other words if the transmitter had been on for 20 minutes and I just need a one minute take, and it's at the end of that 20 minutes, how do I just get, or fast forward, to that one minute? But once I get all that figured out, it will be very impressive. Thank you, Martin Quote Link to comment Share on other sites More sharing options...
IronFilm Posted August 17, 2018 Report Share Posted August 17, 2018 Ideally it would use the timecode on the recorder's file and the TC in the transmitter to automatically match up the segment it wants to pull over. Quote Link to comment Share on other sites More sharing options...
Constantin Posted August 17, 2018 Report Share Posted August 17, 2018 10 hours ago, MartinTheMixer said: It works, it works. It took me a little while to figure it out (I have never operated a Deva). I thought it was new to the Nomad but had been a thing on the Deva for years? Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted August 17, 2018 Author Report Share Posted August 17, 2018 1 hour ago, Constantin said: I thought it was new to the Nomad but had been a thing on the Deva for years? That is correct. Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted August 17, 2018 Author Report Share Posted August 17, 2018 15 hours ago, IronFilm said: Ideally it would use the timecode on the recorder's file and the TC in the transmitter to automatically match up the segment it wants to pull over. Mike, Yes, but so far, I don't know how to do that. As of now, it is not time code stamping the same TC. It is just giving post the offset via sound report. So, if you rolled on a take at 0900, then, 30 minutes later, at 0930, you rerecorded it, it would have a note in the sound report, that reads -30:00. Does that make sense? Thank you, Martin Quote Link to comment Share on other sites More sharing options...
glenn Posted August 17, 2018 Report Share Posted August 17, 2018 The offset is in the note on the new file. In this way there can never be overlapping timecode. This system has worked great for many years Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted August 18, 2018 Author Report Share Posted August 18, 2018 3 hours ago, glenn said: The offset is in the note on the new file. In this way there can never be overlapping timecode. This system has worked great for many years Glenn, Thanks. Is there some way to access (and play) the transmitter recorded file remotely? I.e. without taking the transmitter off of the talent? And don't get me wrong, I am loving this, not only can you rerecord if you have a RF hit, which is pretty rare with Zaxcom, but, you can remix the track recorded to the mixer. I.e., if you had an unexpected level of scream, and you hit the limiters hard in the mixer/recorder, you could rerecord the transmitter file, and since you are rerecording something that has already happened, you know where the scream is at and how many DB to reduce it in order to not hit the limiters. Thank you, Martin Quote Link to comment Share on other sites More sharing options...
glenn Posted August 19, 2018 Report Share Posted August 19, 2018 The files can be replayed while the transmitters are still on the talent. Just cue the Nomad to any location and either Audition or Re-record the audio from any number of transmitters. Quote Link to comment Share on other sites More sharing options...
Jesse Flaitz Posted August 19, 2018 Report Share Posted August 19, 2018 2 hours ago, glenn said: The files can be replayed while the transmitters are still on the talent. Just cue the Nomad to any location and either Audition or Re-record the audio from any number of transmitters. This is fantastic. Thank you very much. Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted August 19, 2018 Author Report Share Posted August 19, 2018 13 minutes ago, Jesse Flaitz said: This is fantastic. Thank you very much. Jesse, If you figure out how to do that, let me know. Thank you, Martin Quote Link to comment Share on other sites More sharing options...
PTA Posted September 5, 2018 Report Share Posted September 5, 2018 Anyone else been playing with this on Nomad? Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted September 6, 2018 Author Report Share Posted September 6, 2018 Yes, I would like to know that too? Quote Link to comment Share on other sites More sharing options...
cstauffer Posted September 6, 2018 Report Share Posted September 6, 2018 Where are you guys finding this firmware version? Quote Link to comment Share on other sites More sharing options...
