Patrick Tresch Posted August 25, 2018 Report Posted August 25, 2018 Hello, I'm looking for a smartphone app (for Iphone) and would like to know wich app is the best. It's mainly to record a lavalier mic (VT506Mobile). I've found that iTalk can do up to 44.1 16bit, but I don't know if there are some differences in the capability of the apps? Or if the limiting factor is the smartphone? What are you thoughts? Thanks Patrick Quote
James Bull Posted August 26, 2018 Report Posted August 26, 2018 I like the free Shure Motiv app, good metering and samplerate/bitrate options, not sure if it will work with your mic, but I think it would. J Quote
Jay Rose Posted August 26, 2018 Report Posted August 26, 2018 I use the Motiv app and mic together. But for all my other mics -- through a Focusrite iTrack -- I use TwistedWave. TW IOS records up to 96 kHz, can be set for 32 bit internal files if you're doing any processing, will record from a Bluetooth source, has decent editing and internal effects, lets you edit metadata... (TW Mac became my go-to desktop editor when I'm not in the studio, after Bias Peak died. So when I needed an app for my phone, it was my first look. Worth investigating.) Quote
IronFilm Posted August 26, 2018 Report Posted August 26, 2018 Timecode Audio Recorder from Tentacle (you'll want their new Tentacle Sync E though):https://itunes.apple.com/nz/app/timecode-audio-recorder/id1322011386?mt=8 Quote
Patrick Tresch Posted August 26, 2018 Author Report Posted August 26, 2018 Thanks you all for your input. 1 hour ago, IronFilm said: Timecode Audio Recorder from Tentacle (you'll want their new Tentacle Sync E though):https://itunes.apple.com/nz/app/timecode-audio-recorder/id1322011386?mt=8 I was wondering if you could record L & R in different levels? It's a mono Lavalier but it would be handy to have a lower gain input. Pat Quote
Jay Rose Posted August 27, 2018 Report Posted August 27, 2018 TwistedWave doesn't let you record a mono signal to two different channels at different levels. But in a phone environment, I don't think you want to do your "dynamic range extension" in software... because that's after the (usually 16-bit) ADC, which is where any noise or clipping would originate. If you're using a mono input (like on many phones), it wouldn't buy you anything at all: what comes out of the ADC is as good as it gets. Why just not just make an adapter that sends the mono signal to both tip and ring of an external digitizer's stereo input, with a simple voltage divider on one channel? If your mic has an XLR, you could put the resistors into the XLR-F connector. I even did that in a QKT adapter I had to throw together for recording phone interviews on a Tascam pocket recorder, so I wouldn't have to worry about sorting local and distant levels in post. Quote
borjam Posted August 28, 2018 Report Posted August 28, 2018 17 hours ago, Jay Rose said: TwistedWave doesn't let you record a mono signal to two different channels at different levels. But in a phone environment, I don't think you want to do your "dynamic range extension" in software... because that's after the (usually 16-bit) ADC, which is where any noise or clipping would originate. If you're using a mono input (like on many phones), it wouldn't buy you anything at all: what comes out of the ADC is as good as it gets. Why just not just make an adapter that sends the mono signal to both tip and ring of an external digitizer's stereo input, with a simple voltage divider on one channel? If your mic has an XLR, you could put the resistors into the XLR-F connector. That's the only way to do it, feeding the mono signal to two different preamps/input stages with different gains/attenuations. The Marantz PMD661mkii (which is often used as a journalist/interview recorder) has that feature, for example, called "dual mono". And I guess it does that, otherwise it would be pointless. Quote
Patrick Tresch Posted September 13, 2018 Author Report Posted September 13, 2018 Thanks all for your replies, I've been using Tentacle recorder since a week (without using the TC feature) and am very happy with the results. I hooked my Smartphone to a Voice Technologies VT506 Mobile lavalier and it does the job nicely. Now I will see in post how it holds... See you. Pat Quote
daniel Posted October 20, 2018 Report Posted October 20, 2018 I wonder if the senny 'memory mic' works with tentacle sync recorder app? Quote
Rick Reineke Posted October 20, 2018 Report Posted October 20, 2018 "I've been using Tentacle recorder (without using the TC feature) and am very happy with the results." -- Same here.. Of coarse a 3.5mm TRRS plug input cable or ext. interface was needed for my iPhone 6s... bizarre wiring config., the plug's sleeve is the + input, ring-2 is shield/ground. Quote
