Mark LeBlanc Posted September 3, 2018 Report Share Posted September 3, 2018 Hey 788t users.. Got one more for you.. This little utility will generate roll numbers for you..You can enter Pre Text that will show up in front of the Roll Number.. You can set how many Numbers are generated. I cap it to 70. You set which number the roll will end..Along with a few other settings you can just play with and figure it out pretty quick.. Just make a change and press Generate button and the result will display below the button. Again, on your iOS device, you enter an email address to send to.. If you have a Mac or PC, the Save button will show up to allow you to save to your desktop. Once on your computer simply connect your 788t to your computer and drag over the "ROLLFOLDERS.SML" file into the top level folder "SOUNDDEV" located in your Internal HD.. CF Card will not work.. I entered some number in with the downloaded version so you can see how it basically works..You need the Filemaker Go app from the App Store to work.. Version 16 and above should work fine.. As with the other utility... Hope it helps someone.... Enjoy! http://louisianafilmsound.com/788t/788t_Roll_Numbers.fmp12 Quote Link to comment Share on other sites More sharing options...
soundchris Posted September 3, 2018 Report Share Posted September 3, 2018 Great info, thank You! Quote Link to comment Share on other sites More sharing options...
